Is possible to keep the contents of the internal EEPROM
pilar
PostPosted: Mon Mar 24, 2014 10:14 am     Reply with quote
I wonder if it is possible to keep the contents of the internal EEPROM of a PIC even after update this with a new firmware, I'm using the ICD2 and Pickit2 ..
PostPosted: Mon Mar 24, 2014 10:30 am     Reply with quote
Pilar, you need to explore your tools more. Select ICD2 as your
debugger in the MPLAB Debugger menu. Then in the same menu,
go down to the Settings menu. Then look at the Program2 tab in
the popup window for Settings. You will find a tickbox there that
will interest you. You need to explore more.
