How to add a selective menu in ex_usb_bootloader.c ?
LiLou
PostPosted: Fri Mar 28, 2014 1:49 am     Reply with quote
I want to add some extra functionalities to the bootloader and I need a menu that waits for an order. I'm using CDC API (usb_cdc.h).
Right now I have:
    HW_INIT();
    unsigned int8 cmd;
    int1 finish=FALSE;
    //unsigned int32 timeout=60000; // ~1 min.
    //we use a button as an event to determine if we should start the USB CDC
    //bootloader.  if button is not pressed then goto the application, else if
    //button is pressed then do the bootloader.
    if(BUTTON_PRESSED())  // Defined in ex_usb_common.h
        usb_init_cs();
        // Wait usb to be ready, I guess
        while(!usb_enumerated())
            // necessary for polling function to work
            #ifdef USB_ISR_POLLING
                usb_task();
        // Main loop
        while(!finish)  //alternative: while(timeout)
            usb_task();
            if (!usb_cdc_kbhit()){
                //timeout--;
                continue;
            cmd = usb_cdc_getc();
            switch(cmd)
                case VERSION_INFO:      //'V'
                    usb_cdc_putc(MAJOR_VER);
                    usb_cdc_putc(MINOR_VER);
                case ERASE_EE:          //'E'
                    clear_eeprom();
                    //timeout=60000;
                case LOAD_PROG:         //'P'
                    load_program();
                    //timeout=60000;
                case ERASE_PROG:        //'e'
                    clear_program();
                    //timeout=60000;
                case QUIT:              //'q'
                    finish=TRUE;
                default:
    #asm
        goto APPLICATION_START
    #endasm
It doesn't work, and I can't discover why as I can't debugg-it.
I believe that the problem has to do with this:
usb_task();
     continue;
That code is also present in load_program()
Do you think the design is fine?
PostPosted: Fri Mar 28, 2014 4:13 am     Reply with quote
No.
That just means 'loop back' and re-test the 'while'.
Odds are, that if you are adding extra functions, the code has got larger. The examples reserve enough space for the code 'as given'. If your code gets more complex, you have to compile it, check it's actual size, and modify the size values in bootloader.h, to work at the next page boundary above the end of your new code.
LiLou
PostPosted: Fri Mar 28, 2014 4:41 am     Reply with quote
Ttelmah wrote:
No.
That is what I want. How then?
Already check it. I'm within the boundary.
LiLou
PostPosted: Fri Mar 28, 2014 6:06 am     Reply with quote
I think I found the error. It's from software, I send strings (not integers), as this strings are null-terminated when bootloader reads the order, the last thing he gets is the null '\0'.
EDIT:
Well, that has only solved part of the problem. The issue is that if I go to load_program, which also does usb_task and usb_cdc_getc (reads the hex file), then the bootloader breaks, doesn't respond. If I do other simpler functions (clear_eeprom, read version), it works well.
