[Solved]Comparison with a negative Integer.
haxan7
PostPosted: Sat Mar 22, 2014 9:26 am     Reply with quote
Compiler Version 5.008
Compiler isn't comparing negative integers correctly. LCD confirms negative int received by the function, but the code in IF is executed every time.
Is this a bug, or am I missing something.
Code Below:
void right(int percent){
   printf(lcd_putc,"\f%d",percent);
   if((int)percent>=0){
      printf(lcd_putc,"\n%d,if",percent);
      output_high(RightC1);
      output_low(RightC2);
   }else{
      percent = -percent;
      output_high(RightC2);
      output_low(RightC1);
      printf(lcd_putc,"\n%d,else",percent);
   pwm2(percent);
PostPosted: Sat Mar 22, 2014 9:30 am     Reply with quote
could be either as 5.008 is a real early however my understanding is that 'int' hmm...defaults to unsigned integer ( 0-255).
The observation that the LCD displays the value correctly just shows the printf functions correctly.
hth
jay
haxan7
PostPosted: Sat Mar 22, 2014 9:42 am     Reply with quote
hth
jay
Any way of fixing this without changing the compiler?
PostPosted: Sat Mar 22, 2014 9:50 am     Reply with quote
hmm. the obvious one is to declare the variable as a signed integer.
If you press F11 while your project is open the CCS HELP manual magically appears, goto contents,goto data definitions,goto basic types....
hth
jay
haxan7
PostPosted: Sat Mar 22, 2014 9:52 am     Reply with quote
Definitely a bug. int should default to signed int by C standard.
using signed int percent instead of int percent fixed the problem.
PostPosted: Sat Mar 22, 2014 10:32 am     Reply with quote
It is NOT a bug just a choice by CCS.
CCS clearly states in the manual that the INT8 defaults to UNSIGNED.
