Drawing waveforms in tft screen which use SSD2119 controller
Posted: Tue Mar 11, 2014 11:49 am
I have bought a TFT display - K350QVG-V2-F which has a SSD2119 controller in it. I am using the tiva launchpad to display waveforms in the TFT screen. I have searched the internet for a long time and have not got any kind of study manual for controlling the display. Is there any kind of booklet which tells how to use that display and the codes with their associated meaning. Any kind of help is appreciated.
Thanks in advance.
Posted: Tue Mar 11, 2014 12:02 pm
The net says:
Tiva C microcontrollers are 32-bit ARM Cortex-M4-based MCUs
I don't need a compiler. I need material for SSD2119 controller or for the display which is quoted above to study and understand how the display works. The link which you provided doesn't have any material which explains the working of the display not any commands which are used to display something on the screen.
Posted: Tue Mar 11, 2014 1:00 pm
Right, but this is not a general electronics support forum. A lot of people
think it is, but it's not. It's about the CCS C compiler and projects that
use that compiler.
There are specific forums for your Tiva-C Arm board, and there are
general electronics forums such as EDAboard that you can use.
