getenv("DEVICE") question
pfournier
PostPosted: Thu Mar 06, 2014 8:46 am     Reply with quote
Using PCWHD 5.020
I tried this preproccesor code:
This is right at the top of may main.c file.
   #if getenv("DEVICE") == "PIC18F4620"
      #define STACK_USE_PICDEM_LCD     1
   #elif getenv("DEVICE") == "PIC18F87J50"
      #define STACK_USE_PICDEM_LCD     0
   #else
      #error Device not defined
It seemed to be working when I put it in the middle of my all day programming session. When I came in this morning and tried a compile it threw up my "Device not defined" error message
For jollies I put:
#device PIC18F87J50
as my first line. The compile worked as expected.
I the REMOVED the #device line and it STILL compiled.
I had hoped getenv("DEVICE") would be reading the processor setup in either the Compile Menu, or the Options/Project/General/Target, but by modifying the #device value it modifies the target in the Compile Menu, and the Options/Project/General/Target.
The big thing that bothers me is that removing the #device value doesn't change anything.
Am I missing something here?
-Pete
