blixxman
RS232 control |
Posted: Mon Mar 03, 2014 3:16 pm |
I have the following problem and needs help.
I have written the code below to control LEDs on the specified ports. However, I have to hit character 3 times before LED turns ON.
what am I not doing correctly?
#include <18F2520.h>
#device adc=16
#FUSES INTRC //High speed osc with HW enabled 4X PLL
#FUSES LVP //Low voltage prgming
#FUSES NOXINST //Extended mode disabled (Legacy mode)
#use delay(clock=8000000)
#include <stdio.h>
while(true){
if(kbhit()){
if(getc()=='a')
output_high(PIN_B7);
printf("led1 on\r\n");
if(getc()=='b')
output_low(PIN_B7);
printf("led1 Off\r\n");
if(getc()=='c')
output_high(PIN_B6);
printf("led2 on\r\n");
if(getc()=='d')
output_low(PIN_B6);
printf("led2 off\r\n");
Posted: Mon Mar 03, 2014 3:37 pm |
1) Not using the code buttons....
2) Correct the remarks. These mislead both us, and you. For instance, you are not using the PLL.
3) Get rid of the LVP fuse. Use NOLVP. 99% of systems do not use low voltage programming. With LVP enabled, unless the pins that handle this are correctly resistor biased to disable the programming, the chip will _not_ run properly.
4) Add 'ERRORS' to your RS232 setup. Repeat 50*, "when using the hardware UART, you _must_ have the ERRORS parameter, unless _you_ handle errors yourself".
5) _Think_. Each 'getc', gets a character. Each one will only respond to the one character specified, and throw the character away. So to get to (say) the third one, three earlier characters will need to be received. You need to read the character _once_, and then do all the tests on this one character :
int8 char_rcvd;
if(kbhit())
char_rcvd=getc();
if(char_rcvd=='a')
if(char_rcvd=='b')
//etc....
Also, realise you can code this as a 'switch'.
The last is the main reason it is not working, but the former ones are all 'waiting to catch you later'. |
blixxman
Posted: Mon Mar 03, 2014 5:45 pm |
Thanks Ttelmah...it works |
