MMC code problem
farouk_baya
MMC code problem
PostPosted: Sat Feb 22, 2014 4:03 am     Reply with quote
I'm working actually on a project using an SD card FAT32.
I'm using ISIS Proteus 7.8 SP2 and I'm using PIC C 5.007.
The problem is that the fat_init() returs always 0.
#include <18F2550.h>
#device PASS_STRINGS = IN_RAM
#fuses NOWDT, HS, NOPROTECT
#use delay(clock=20M)
#use rs232(baud=9600, UART1, errors)
#include <stdlib.h> // for atoi32
//media library, a compatable media library is required for FAT.
// SPI master PIN configuration
#use fast_io(c)
#define MMCSD_PIN_SCL     PIN_B1 //o
#define MMCSD_PIN_SDI     PIN_B0 //i
#define MMCSD_PIN_SDO     PIN_C7 //o
#define MMCSD_PIN_SELECT  PIN_C0 //o
#include <mmcsd.c>
//FAT library.
#include <fat.c>
   int i;   // pointer to the buffer
   printf("\r\n --------------");
   printf("\r\n Program begin");
   printf("\r\n ");
   // initialize the FAT
   //  keep in mind that this will automatically initialize the media
   i = fat_init();
   if (i)
      printf("\r\n\nERROR INITIALIZING FAT\r\n\n");
   // main loop
PostPosted: Sat Feb 22, 2014 4:19 am     Reply with quote
How are you converting the voltage levels between the PIC, and the SD card?.
This is the oldest, commonest problem....
The PIC2550 is a basically 5v device (it can operate down to 4.2v minimum). The SD card is 3.3v. The PIC SDI input, requires the signal to go up to at least 0.8*Vdd to be seen as '1' (4v with the 5v PIC). The SD card only guarantees to produce 2.475v for Voh (with a 3.3v supply). Result, PIC can't see the signal.....
You need to either be using a 3.3v PIC (best solution), or have proper buffers between the chips. Look at the 'ethernet reference design' on the Brush Electronics site:
<http://www.brushelectronics.com/index.php?page=projects>
Which shows using a logic chip as a buffer.
5.007, is a little 'borderline' for V5, A slightly later version, or 4.141, is generally more reliable. Also look in the code library, for the fixes to handle MBR operation with the CCS drivers (and fix one long standing error). These are 'needed'.
PostPosted: Sat Feb 22, 2014 7:15 am     Reply with quote
