PIC18F6722 to PIC18F67K22 migration
heliodoro.alegre
PostPosted: Fri Feb 21, 2014 6:54 am     Reply with quote
I have updated a board from PIC18F6722 to PIC18F67K22
PORT_C does not work.
I have all pins as output. In PIC18F6722 worked correctly
but in PIC18F67K22 PIN_C0, PIN_C1 seems configured as
input, or oscillator, but do not output.
I have tried to solve with:
#FUSES INTRC_IO // Internal RC Osc
#use FIXED_IO (c_outputs=PIN_C0, PIN_C1, PIN_C2, PIN_C3, PIN_C4, PIN_C5, PIN_C6, PIN_C7) // leds
I think new features in PIC18F67K22 are interfering IO function.
What #fuses #use setup_?? is needed in PIC18F67K22 with
compiler version 4.114 to use PIN_C0 and PIN_C1 as output?
PostPosted: Fri Feb 21, 2014 7:08 am     Reply with quote
See this thread about the SOSC_DIG fuse:
http://www.ccsinfo.com/forum/viewtopic.php?t=48306
Fabri
PostPosted: Tue Mar 25, 2014 3:24 pm     Reply with quote
Thanks PCM programmer... now it's work. I did search in forum but I didn't found nothing so I ask help. I'll study better this configuration.
Regards,
Fabri
