PIC24FV32KA301 start-up issues
starfire151
PostPosted: Tue Feb 11, 2014 5:32 pm     Reply with quote
I'm using PCWHD version 4.137. I've been using the PIC18F family of processors but want to migrate into the PIC24FV family. I created a small program (below) to test the functionality.
With the #use delay(clock=32000000) line and the #use rs232(baud=38400, parity=N, xmit=PIN_A2, rcv=PIN_B2, bits=8) line, I see the output com at 19200 baud (half the rate I expected).
I am also not seeing the LED connected to pin 9 (bit RB4) toggle.
Have I got all the fuses set correctly? I think I specified the internal clock using the *4 PLL for an internal rate of 32MHz? I also specified that the OSCIO pins should be used for general I/O?
It appears the timer ISR is working correctly, though. I tried to set it up for the timer ISR to go off 10 times a second. Every 10th time, it toggles the LED and bumps a running count. The count printed does appear to be incrementing but two sometimes though (once from the background and once from the timer ISR). Again, I'm not seeing the LED toggle.
Any help would be appreciated. This looks to be a very powerful processor but I'm having start-up problems...
#include <24FV32KA301.h>
#device adc=12
#fuses ICSP1         // select ICSP1 programming port
#fuses NOWDT
#fuses NOPROTECT
#fuses MCLR
#fuses PUT
#fuses NOBROWNOUT
#fuses FRC_PLL       // PLL (osc * 4) High speed osc
#fuses OSCIO         // oscillator pins used as general purpose I/O
#define INTS_PER_SEC 10       // (32,000,000 / (2 * 256)) / 6250
// ---- define I/O default port data and TRIS parameters ----
#define PA_DEF 0b1111111111111111
#define PA_TRIS 0b1111111111111011
   // 15  I: NA on 20-pin PIC
   // 14  I: NA on 20-pin PIC
   // 13  I: NA on 20-pin PIC
   // 12  I: NA on 20-pin PIC
   // 11  I: NA on 20-pin PIC
   // 10  I: NA on 20-pin PIC
   // 9   I: NA on 20-pin PIC
   // 8   I: NA on 20-pin PIC
   // 7   I: NA on 20-pin PIC
   // 6   I: VCap on FV part
   // 5   I: Pin 1 : MCLR
   // 4   I: Pin 10 : unused
   // 3   I: Pin 8 : unused
   // 2   O: Pin 7 : Tx output to terminal
   // 1   I: Pin 3 : unused
   // 0   I: Pin 2 : unused
#define PB_DEF 0b1111111111101111
#define PB_TRIS 0b0100111111101111
   // 15  O: Pin 18 : unused
   // 14  I: Pin 17 : unused
   // 13  O: Pin 16 : unused
   // 12  O: Pin 15 : unused
   // 9   I: Pin 13 : unused
   // 8   I: Pin 12 : unused
   // 7   I: Pin 11 : unused
   // 6   I: NA on 20-pin PIC
   // 5   I: NA on 20-pin PIC
   // 4   O: Pin 9 : heartbeat
   // 3   I: NA on 20-pin PIC
   // 2   I: Pin 6 : Rx input from terminal
   // 1   I: Pin 5 : PGEC1 prog clock
   // 0   I: Pin 4 : PGED1 prog data
#define HEARTBEAT PIN_B4      // 1-second heartbeat toggle
// ---- variable definitions ----
int16 intCount;         // interrupt counter
int32 secondsTotal;     // total count of running seconds
// ---- initialize the system routine ----
void InitSys(void)
   output_a(PA_DEF);
   output_b(PB_DEF);
   intCount = INTS_PER_SEC;
   secondsTotal = 0;
// ---- real time clock interrupt routine ----
#INT_TIMER1
void ClockISR(void)
   intCount--;
   if(intCount == 0)
      intCount = INTS_PER_SEC;   // reinit timer ints per msec cntr
      output_toggle(PIN_B4);     // toggle heartbeat output pin
      secondsTotal++;            // increment local total seconds count
// ---- main program beginning ----
   setup_adc_ports(sAN0);
   set_tris_a(PA_TRIS);
   set_tris_b(PB_TRIS);
   setup_timer1(TMR_INTERNAL | TMR_DIV_BY_256, 6250);  // 0.1 sec interrupt
   InitSys();
   delay_ms(10);
   printf("PIC24FV32KA301 Testbed\r\n");
   printf("V1.0  Compiled: %s  %s\r\n", __DATE__, __TIME__);
   printf("\r\n");
   clear_interrupt(INT_TIMER1);
      printf("while() loop %lu...\r\n", secondsTotal);
      output_low(PIN_B4);
      delay_ms(400);
      output_high(PIN_B4);
      delay_ms(400);
      secondsTotal++;
PostPosted: Wed Feb 12, 2014 2:33 am     Reply with quote
Make just two changes:
Get rid of the FRC_PLL fuse, and change the clock line to:
#use delay(internal=32000000).
Problem is that to setup the PLL, the CLKDIV register has to be set as well as the fuses. Because you are saying 'I have control' (setting the fuses, and telling the compiler what clock is being generated), the compiler leaves it to you to set this. However you are not doing it, so it wakes up at a default setting (looks like 4MHz*4).
By instead telling the compiler you want to use the internal oscillator at 32MHz, it changes to saying "right, I've got to set the CLKDIV register".
Select the fuse SOSC_DIGITAL to get RB4 to work.
starfire151
PostPosted: Wed Feb 12, 2014 8:58 am     Reply with quote
Thanks very much for your help.
