Problem between #INT_EXT and #INT_RB
pilar
PostPosted: Wed Feb 05, 2014 7:05 pm     Reply with quote
Hi, anyone can help me with this,
I'm trying to use the #INT_EXT and #INT_RB but each with different edge on which the edge interrupt should trigger, #INT_EXT is rise edge (L to H) and #INT_RB is fall edge (H to L), but when two interrupts are enabled #INT_EXT only active with fall edge, but when I disable #INT_RB, #INT_EXT works OK, it is activated by the rising edge ... what is the problem?
Here is my code:
#include <18F4520.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7, timeout=5000)// RS232 Estándar
int Clear_PORTB;
#INT_EXT
void Int_CALL(){
output_toggle(PIN_D0);
#INT_RB
void Int_DOOR(){
   output_toggle(PIN_D3);
Clear_PORTB = input_b();
    ext_int_edge(L_TO_H);
    clear_interrupt(INT_EXT);
    enable_interrupts(int_ext);
    ext_int_edge( H_TO_L );
    clear_interrupt(INT_RB);
    enable_interrupts(int_rb);
    enable_interrupts(global);
while(TRUE) {
PostPosted: Wed Feb 05, 2014 8:15 pm     Reply with quote
The function in bold is not used for INT_RB. It's only for INT_EXT.
The 18F4520 doesn't have the ability to select the edge for INT_RB.
pilar
PostPosted: Thu Feb 06, 2014 8:03 am     Reply with quote
Hi PCM programmer,
Thank you... Embarassed the error is so obvious!!!
