18f46j50 i2c master and slave mode
hamid9543
PostPosted: Sat Jan 25, 2014 9:40 am     Reply with quote
hi
I want to use 18f46j50 in master and slave mode i2c.
In master mode read from device(such as compass) and in slave mode send data to other micro.
Can you help me for config code and wire conection?
thanx
PostPosted: Sun Jan 26, 2014 1:45 am     Reply with quote
Read the data sheet.
This tells you what pins SDA1, SDA2, SCL1, and SCL2 are on.
Use these pins.
Then just have two #use I2C statements. One setting up a master (with the clock rate your peripheral requires), using the pins for one of the ports. Give this a stream name of perhaps 'MASTER'. Then a second #use I2C setting up a slave on the other port. Perhaps called 'SLAVE'. In each case have FORCE_HW. Remember the slave address will need to be what the other 'master' wants to talk to.
Then code is exactly the same as the many examples supplied with the compiler, in the code library, and posted here, except that the slave code, must have the stream designator added to each I2C statement (SLAVE), and the the master code must have it's stream designator added to it's statements.
You can't generally 'switch modes' with normal I2C, so just use the two ports. Trying to change modes can easily lead to bus collisions, and should only be done with devices 'built' to handle this on the bus (multi-master). Unless your other 'master' device, has the bus arbitration to handle multi-master operations, then this is a recipe for disaster. Much safer and easier to use the two ports.
tems
I2C master and slave
PostPosted: Mon Jan 27, 2014 8:17 am     Reply with quote
If you are using version 5.16 and possibly earlier you must setup the #use I2C as given below. Version 5.17 does not exhibit this problem.
From CCS
The problem is due to an error in the #use i2c() directive. I have fixed the problem and it will be available in the next compiler release. However the problem only occurs if the #use i2c() directive setting up the HW slave is above the #use i2c() directive setting up the HW master. So the quick solution to your problem is to move your #use i2c(Master,Fast,I2C2,restart_wdt,force_hw,stream=eemem) line above your #use i2c(Slave,Fast,I2C1,restart_wdt,force_hw,address=0x20,stream=com) line.
