Expression must evaluate to a constant
oxo
PostPosted: Mon Jan 20, 2014 9:05 am     Reply with quote
Hi all,
I'm using the ccs usb HID code, and trying to save some RAM, I have added
#device CONST=ROM
This causes the above error in usb_desc_hid.h at this line:
USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[0][0], 0x00, //length of report descriptor            ==26,27
Without the #device CONST=ROM, there is no error, but I run out of ram.
I am quite confused by this because the structure definition is
const char USB_CONFIG_DESC[] = {.... etc
CCS version 5.016
PIC 18F25K50
asmboy
PostPosted: Mon Jan 20, 2014 12:24 pm     Reply with quote
what bearing do you think this has on your shortage?
CONST by default are stored in program rom memory as it is.
what do you see in the .LST file ??
have U considered defining the array size explicitly?
PostPosted: Mon Jan 20, 2014 1:42 pm     Reply with quote
I made a new project for ex_usb_hid.c, and edited it for an 18F25K50 and
compiled it with vs. 5.016. I got the same error. I think it may be a
bug in the compiler. Maybe it doesn't like you re-declaring a configuration
that exists as the default, i.e., CONST=ROM.
How ? The compiler reports only 10% or 11% ram usage:
CCS PCH C Compiler, Version 5.016, xxxxx       20-Jan-14 11:37
               Filename:   C:\Program Files\PICC\Examples\ex_usb_hid.lst
               ROM used:   5158 bytes (16%)
                           Largest free fragment is 27610
               RAM used:   197 (10%) at main() level
                           231 (11%) worst case
               Stack used: 13 locations (4 in main + 9 for interrupts)
               Stack size: 31
.................... #device PIC18F25K50
