maxD
#int_rda problem |
Posted: Fri Jan 03, 2014 2:49 am |
Hi guys!
In the ex_sisr.c example , #int_rda written using getc().
But, can we use get_string() instead of getc() inside #int_rda ISR? |
asmallri
Posted: Fri Jan 03, 2014 2:52 am |
Yes. You can do virtually anything you like but it will not do you any good - it will not produce a useful result.
You will receive an interrupt for each character received. Look at examples implementing a serial receive ring buffer. _________________ Regards, Andrew
asmboy
Posted: Fri Jan 03, 2014 2:53 pm |
Quote: |
can we use get_string() |
i suggest you use a big enough ISR buffer,
and scan it for a \13 , swap it for a \0
then copy the appropriate chars out when your
string terminator is found, making a buffered , virtual get_string();
you could save a lot of looking by comparing each ISR received char to your string term char- and set the flag when it is seen -
if the flag is an INT8
it can be =0 when no str_term has arrived - then
when TRUE make it be equal to the offset in the ISR buffer
WHERE it was seen ( more chars might arrive you know)
-and be very efficient as well |
