Example using motor PWM with DSPIC30F2010
Eduardo__
PostPosted: Mon Dec 23, 2013 8:41 pm     Reply with quote
Example using motor PWM with DSPIC30F2010:
Just for sharing with people who needs it:
It´s a little confuse understanding how motor pwm works, but, for example, it is possible to adjust it for several configurations.
In the example below I set it for generating two different PWM with inverted outputs. The other 4 PWM pins of DSPIC30F2010 remain disabled(can be used for others things or io ports).
//MOTOR PWM(using example)
setup_timer1(TMR_INTERNAL,3333);     //setups PWM frequency
setup_motor_pwm(1,MPWM_FREE_RUN,1,0,255); //setups PWM
set_motor_unit(1,1,MPWM_ENABLE_L,1,1);  //setups first PWM
set_motor_pwm_duty(1,1,20);      //Adjusts first pwm duty
set_motor_unit(1,2,MPWM_ENABLE_L,1,1);  //setups second PWM
set_motor_pwm_duty(1,2,100);     //Adjusts second pwm duty
Good luck folks!! ;)
Have a very merry Xmas *<:o)
Eduardo Guilherme Brandt
