Problem with flex lcd driver
yuripace
PostPosted: Tue Dec 10, 2013 2:22 pm     Reply with quote
i have a problem with this driver, sure for my error Smile
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
i'm using pic16f876 and LCD HD44780 (QC1602a reported on the LCD), and i changed flexdriver with this pins
#define LCD_DB4   PIN_B0
#define LCD_DB5   PIN_B1
#define LCD_DB6   PIN_B2
#define LCD_DB7   PIN_B5
#define LCD_E     PIN_A1
#define LCD_RS    PIN_A0
#define LCD_RW    PIN_A2
//#define USE_LCD_RW   1
this is the sample program
#include <16F876.h>
#fuses XT, NOWDT, NOLVP, NOPROTECT,NOBROWNOUT, NODEBUG, PUT
#use delay(clock = 4000000)
#include "..\_inc\types.h"
#include "flexlcd.c"
void main
   lcd_putc("\fCiao\n");
   output_high(PIN_B4);
   output_low(PIN_B4);
RW is connected to the ground, trimmer to regulate the contrast and pin A and K connected to retroillumination. Proteus simulation is working, but unfortunately i see only black square or strange character.
Whats the problem?
PostPosted: Tue Dec 10, 2013 3:54 pm     Reply with quote
Wait at the start _before_ calling lcd_init.
LCD's take a long time to wake up after power is applied. Many 'third party' clone chips take longer than the original Hitachi controllers, and also the chips often don't start to wake till the power rail gets up to perhaps 4.5v, while the PIC will often start to wake when the rail gets up to only perhaps 3v.
No pause is needed after lcd_init.
Proteus tends to get timings like this wrong.....
Generally, as a separate comment, it is bad practice to have the code 'dropping off the end'. Study all examples, and you will see a loop or similar operation to stop this.
yuripace
PostPosted: Thu Dec 12, 2013 1:30 pm     Reply with quote
i added a
before the lcd_init and a loop at the end of the program, but the situation wont change..any ideas? :(
thanks
Yuri
PostPosted: Thu Dec 12, 2013 1:47 pm     Reply with quote
Look at this drawing of the LCD connections:
www.mikroe.com/img/publication/8051-books/programming-8051-mcu/chapter/ch6/20.gif
These pins below, should connect to pins D4 to D7 on the LCD.
Make sure you have those connections done correctly.
The LCD pins for D0 to D3 should be unconnected. They are not used.
Carefully check all the other connections.
yuripace
PostPosted: Thu Dec 12, 2013 1:58 pm     Reply with quote
all the connection seems correct. i do not have resistor on background light, but i think this is not the problem.
maybe i'm missing some pic initialization? led is working correctly.
yuripace
PostPosted: Thu Dec 12, 2013 2:08 pm     Reply with quote
ehm..coff coff..wrong connection Smile
now its working!!! :D
many thanks!!!
