26K22 pullup on E3 -> Compiler error 5.016
hmmpic
PostPosted: Thu Dec 12, 2013 7:00 am     Reply with quote
Hi
Compiler 5.016
Is this looking right?
I dont understand the asm. code, register F86.6? is not existing in the chip 26K22? And the RBPU = 0 is High therefore no pullup at all.
Is there error in the compile??
//Only for test, therefore no sw or other thing!
#include <18F26K22.h>
void main(void) {
 port_b_pullups(0x00);//no pull up on port b
 port_e_pullups(0x08);//pullup on port e pin_e3!!! It can only be input! If no pullup it will float:-((((
List code:
0001E:  CLRF   WPUB
00020:  BSF    INTCON2.RBPU
....................  port_e_pullups(0x08);//pullup on port e pin_e3!!! It can only be input! If no pullup it will float:-((((
00022:  BCF    F86.6
This is from the Datasheet:
10.6.3 RE3 WEAK PULL-UP
The port RE3 pin has an individually controlled weak
internal pull-up. When set, the WPUE3 (TRISE<7>) bit
enables the RE3 pin pull-up. The RBPU bit of the
INTCON2 register controls pull-ups on both PORTB
and PORTE. When RBPU = 0, the weak pull-ups
become active on all pins which have the WPUE3 or
WPUBx bits set. When set, the RBPU bit disables all
weak pull-ups. The pull-ups are disabled on a Poweron
Reset. When the RE3 port pin is configured as
MCLR, (CONFIG3H<7>, MCLRE=1 and
CONFIG4L<2>, LVP=0), or configured for Low Voltage
Programming, (MCLRE=x and LVP=1), the pull-up is
always enabled and the WPUE3 bit has no effect
PostPosted: Thu Dec 12, 2013 9:14 am     Reply with quote
Yes. Report it to CCS, and just bodge round temporarily with:
#BIT RBPU=getenv("BIT:RBPU")
void main(void) {
 RBPU=0;
On most chips, RBPU, only controls the port B pullups (hence the 'B' in it's name). So the compiler when it sees all the pull up bits on port B set to '0', turns this bit off. On this chip it also controls the port E pullups, so needs to be on if any bit is set here, but the compiler hasn't got this sorted.
Hurrah!. A really nice sized test program. Smile
hmmpic
PostPosted: Thu Dec 12, 2013 9:47 am     Reply with quote
Hi
Just sent a support mail to CCS.
Thanks for testing, too:-)
