USB HID Receiving Caps Lock,Num Lock,ETC Conditions
HasanOzkaya
PostPosted: Mon Nov 25, 2013 2:13 am     Reply with quote
i used ex_usb_kbmouse2.c for hid kb device , the transmit part works fine and i understood but i confused on receive part. I can get some data when i press the Caps Lock , Num Lock but i coundt find what are these.
Here is the code
////                        ex_usb_kbmouse2.c                        ////
//// An example of creating a mouse and keyboard combo USB device,   ////
//// implemented by using multiple HID reports.  One HID report is   ////
//// used for the mouse, another HID report for the keyboard.        ////
//// Uses your operating system's HID drivers, which on most systems ////
//// should already be installed.  Multiple HID reports is easy to   ////
//// implement, but you lose bandwidth as the mouse and keyboard     ////
//// must share the same endpoint.  See ex_usb_kbmouse.c which       ////
//// implements a combo device using multiple interfaces.            ////
//// Once enumrated, the PIC will move the mouse cursor around in    ////
//// a circle if the button is held down.  Also, whenever the        ////
//// button is held down the PIC will send an 'a' as a keyboard      ////
//// press.  (open a text editor to see the 'a' being sent)          ////
//// For a more generic USB HID example (as well as some HID         ////
//// documentation) see ex_usb_hid.c                                 ////
//// VERSION HISTORY                                                 ////
//// June 20th, 2005: Initial 18fxx5x release.                       ////
//// May 13th, 2005: Initial Beta.  Only works with 18Fxx5x          ////        ////
////        (C) Copyright 1996,2005 Custom Computer Services         ////
//// This source code may only be used by licensed users of the CCS  ////
//// C compiler.  This source code may only be distributed to other  ////
//// licensed users of the CCS C compiler.  No other use,            ////
//// reproduction or distribution is permitted without written       ////
//// permission.  Derivative programs created using this software    ////
//// in object code form are not restricted in any way.              ////
//set to 1 to use a PIC's internal USB Peripheral
//set to 0 to use a National USBN960x peripheral
#define __USB_PIC_PERIF__ 1
#if __USB_PIC_PERIF__
 #DEFINE LED1  PIN_A5
 #if defined(__PCM__)
    #include <16C765.h>
    #device *=16
    #fuses HS,NOWDT,NOPROTECT
    #use delay(clock=24000000)
 #elif defined(__PCH__)
    #include <18F4550.h>
    #fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
    #use delay(clock=48000000)
#else //use the National USBN960x peripheral
 #DEFINE LED1  PIN_B3
  #include <16F877A.h>
  #device *=16
  #include <18F452.h>
#endif   //endif check to see which peripheral to use
// CCS Library dynamic defines.  For dynamic configuration of the CCS Library
// for your application several defines need to be made.  See the comments
// at usb.h for more information
//Tells the CCS PIC USB firmware to include HID handling code.
#DEFINE USB_HID_DEVICE  TRUE
//the following defines needed for the CCS USB PIC driver to enable the TX endpoint 1
#define USB_EP1_TX_ENABLE  USB_ENABLE_INTERRUPT   //turn on EP1 for IN bulk/interrupt transfers
#define USB_EP1_TX_SIZE 8
#define USB_EP1_RX_ENABLE  USB_ENABLE_INTERRUPT   //turn on EP1 for IN bulk/interrupt transfers
#define USB_EP1_RX_SIZE 8
// If you are using a USB connection sense pin, define it here.  If you are
// not using connection sense, comment out this line.  Without connection
// sense you will not know if the device gets disconnected.
//       (connection sense should look like this:
//                             100k
//            VBUS-----+----/\/\/\/\/\----- (I/O PIN ON PIC)
//                     +----/\/\/\/\/\-----GND
//                             100k
//        (where VBUS is pin1 of the USB connector)
///only the 18F4550 development kit has this pin
#if __USB_PIC_PERIF__ && defined(__PCH__)
 #define USB_CON_SENSE_PIN PIN_B2
// Include the CCS USB Libraries.  See the comments at the top of these
// files for more information
  #include <pic_usb.h>   //Microchip PIC16C765 hardware layer for usb.c
 #else
  #include <pic18_usb.h>
#else
 #include <usbn960x.c>   //National 960x hardware layer for usb.c
#include <usb_desc_kbmouse2.h>    //USB Configuration and Device descriptors for this UBS device
#include <usb.c>        //handles usb setup tokens and get descriptor reports
#include <EXLCD.C>
// Configure the demonstration I/O
#define BUTTON PIN_A4
#define LED2 PIN_B4
#define LED3 PIN_B5
#define LED_ON output_low
#define LED_OFF output_high
// usb_debug_task()
// When called periodically, displays debugging information over serial
// to display enumeration and connection states.  Also lights LED2 and LED3
// based upon enumeration and connection status.
void usb_debug_task(void) {
   static int8 last_connected;
   static int8 last_enumerated;
   int8 new_connected;
   int8 new_enumerated;
   new_connected=usb_attached();
   new_enumerated=usb_enumerated();
   if (new_connected)
      LED_ON(LED2);
      LED_OFF(LED2);
   if (new_enumerated)
      LED_ON(LED3);
      LED_OFF(LED3);
   if (new_connected && !last_connected)
      printf("\r\n\nUSB connected, waiting for enumaration...");
   if (!new_connected && last_connected)
      printf("\r\n\nUSB disconnected, waiting for connection...");
   if (new_enumerated && !last_enumerated)
      printf("\r\n\nUSB enumerated by PC/HOST");
   if (!new_enumerated && last_enumerated)
      printf("\r\n\nUSB unenumerated by PC/HOST, waiting for enumeration...");
   last_connected=new_connected;
   last_enumerated=new_enumerated;
// usb_mouse_task()
// Sends a packet of data containing mouse information.  The protocol was
// defined in the HID report descriptor (see usb_desc_kbmouse2.h), and is:
//   out_data[0]=HID report id (1)
//   out_data[1]=button state
//   out_data[2]=x delta
//   out_data[3]=y delta
//   out_data[4]=wheel delta
void usb_mouse_task(void) {
   #define MOUSE_SEQUENCE_STEPS  16
   const char mouse_seq[MOUSE_SEQUENCE_STEPS]=
   {0, 1, 3, 4, 4, 4, 3, 1, 0, -1, -3, -4, -4, -4, -3, -1};
   static int8 out_data[5]={1,0,0,0,0};
   static int8 x_seq=0;  static int8 y_seq=MOUSE_SEQUENCE_STEPS/4;
   static int8 skip=0;
   if (input(BUTTON)) {
      out_data[2]=mouse_seq[x_seq];
      out_data[3]=mouse_seq[y_seq];
   else {
      out_data[2]=0;
      out_data[3]=0;
   if (usb_put_packet(1,out_data,5,USB_DTS_TOGGLE)) {
      skip++;
      if (skip>10) {
         if (++x_seq>=MOUSE_SEQUENCE_STEPS) {x_seq=0;}
         if (++y_seq>=MOUSE_SEQUENCE_STEPS) {y_seq=0;}
         skip=0;
// usb_keyboard_task()
// Sends a packet of keyboard data.  The protocol was specified in the HID
// report descriptor (see usb_desc_kbmouse.h), and is:
//     tx_msg[0] = HID report id (2)
//     tx_msg[1] = modifier (an 8bit bitmap of shift, tab, alt keypress)
//     tx_msg[2] = const 0
//     tx_msg[3:7] = an array of held down keys.  a=4, b=5, etc.
//                   if msg[2:7]={0} then no keys are held down
//     rx_msg[1] = HID report id (2)
//     rx_msg[0] = 5bit bitmap of led status
void usb_keyboard_task(void) {
   static int8 tx_msg[8]={2,0,0,0,0,0,0,0};
   if (input(BUTTON))
      tx_msg[3]=4;
      tx_msg[3]=0;
   usb_put_packet(1,tx_msg,sizeof(tx_msg),USB_DTS_TOGGLE);
// usb_rx_task()
// Listens to EP1 for any incoming packets.  The only report ID that is
// configurd to send us data is 2 (keyboard LED status, see above)
void usb_rx_task(void) {
   int8 rx_msg[USB_EP1_RX_SIZE];
   if (usb_kbhit(1)) {
      usb_get_packet(1, rx_msg, sizeof(rx_msg));
            printf(lcd_putc,"\f");
    printf(lcd_putc," %d ",rx_msg[1]);
      if(rx_msg[0]!=0)
      output_high(PIN_D0);
      if(rx_msg[1]!=0)
      output_high(PIN_D1);
      if(rx_msg[2]!=0)
      output_high(PIN_D2);
      if(rx_msg[3]!=0)
      output_high(PIN_D3);
      if(rx_msg[4]!=0)
      output_high(PIN_D4);
   int8 which=0;
lcd_init();
   LED_ON(LED1);
   LED_OFF(LED2);
   LED_OFF(LED3);
   printf("\r\n\nCCS HID Mouse/Keyboard Multiple HID Report Demo");
   printf("\r\nPress button to make mouse move in a circle and ");
   printf("send an A over the keyboard");
  #ifdef __PCH__
   printf("\r\nPCH: v");
   printf(__PCH__);
  #else
   printf("\r\n\PCM: v");
   printf(__PCM__);
   usb_init_cs();
  #if !(__USB_PIC_PERIF__)
   printf("\r\nUSBN: 0x%X", usbn_get_version());
   printf("\r\n");
   while (TRUE) {
      usb_task();
      usb_debug_task();
      if (usb_enumerated()) {
         if (which) {
            usb_mouse_task();
            which=0;
         else {
            usb_keyboard_task();
            which=1;
         usb_rx_task();
         delay_ms(10);
