define an array of constants including the character (,)
pilar
PostPosted: Tue Nov 26, 2013 11:27 am     Reply with quote
Hello, I want to define an array of constants including the character (,) but does not allow me to do so, is there any way to define this ("CGREG 1.1)?
const char Strings[TOTAL_STRINGS][SIZE_COMMAND]={"OK\0",      // index 0
                  "CGREG:1,1\0",      // index 1
                  "+CMTI\0",      // index 2
                  "ERROR\0",      // index 3
PostPosted: Tue Nov 26, 2013 1:15 pm     Reply with quote
You can include any character, by using it's octal or hex value,
So \x2C or \053 generates a comma.
PostPosted: Tue Nov 26, 2013 1:17 pm     Reply with quote
It works for me. I compiled the program shown below in vs. 5.016 and
ran it in MPLAB simulator, and I got the following output. It displays the comma:
CGREG:1,1
Here is the test program:
#include <18F4520.h>
#fuses INTRC_IO, BROWNOUT, PUT, NOWDT
#use delay(clock=4M)
#define TOTAL_STRINGS 4
#define SIZE_COMMAND  11
                 {"OK\0",      // index 0
printf(Strings[1]);
Note that the compiler automatically puts a 0x00 byte at the end of each
string (this is part of the definition of a string). You are adding an extra
0x00 on the end of each string, for some unknown reason. So you really
have two zeros at the end of each string.
PostPosted: Tue Nov 26, 2013 1:51 pm     Reply with quote
I wonder if he is running out of space?.
Doesn't show the declaration for 'SIZE_COMMAND', and with the extra terminators, would need 11 characters for this line.
pilar
PostPosted: Tue Nov 26, 2013 7:14 pm     Reply with quote
Ok, Thank you..
