How can i use div.ud in compiled result?
Kim Cheolho
PostPosted: Wed Nov 27, 2013 3:56 pm     Reply with quote
Hi!
I need high speed division unsigned 32bit/16bit.
But compiler does't support div.ud command.
Only private code which take long long time.
So I made #asm code like below.
How can i use div.ud in compiled result like MyDiv code?
//////  sample code for dsPIC30F2011
//////  Compiler version is 5.016
unsigned int16 MyDiv(unsigned int32 i32, unsigned int16 i16)
   unsigned int16 hi,lo, rt;
   lo = (unsigned int16)i32;
   hi = (unsigned int16)(i32>>16);
#asm
   mov lo, w6;
   mov hi, w7;
   mov i16, w8;
   repeat #17;
   div.ud w6, w8;
   mov w0, rt;
#endasm
return rt;
unsigned int32 i32 = 691200;
unsigned int16 i16 = 500;
unsigned int16 result;
      result = i32 / i16;
      result = MyDiv(i32, i16);
Very Happy
PostPosted: Thu Nov 28, 2013 2:33 am     Reply with quote
You already are...
Nothing better at the moment, _but_ point out to CCS, that these chips have a hardware unsigned division, and hopefully they will consider adding it's use to their code.
