My exercise B under the USB Master Exerise Book not working.
Mark A Carter
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Wed Nov 06, 2013 2:59 pm     Reply with quote
Confused
Dear programmers.
I am trying to get the exercise B under the "USB Master Exercise Book" to function. Under the FURTHER STUDY section of the book to write a MACRO called "delay_seconds".
I am a novice C programmer just starting out.
It should turn on the Green LED D5 for five seconds then turn it off for five seconds then turn on the Yellow D1 LED for one second then turn it off for one second then finally turn the RED LED D0 on for five seconds then turn it off for five seconds then this program repeats this sequence. Please see my code below. I have attempted this exercise using an example code clip from a CCS compiler help topic. This work is done on the CCS Company PIC18F67J10 trainer PCB. My IDE version is 5.013 .
This is my first request for help under the CCS Forum Index -> General CCS C Discussion.
Thank you for your help.
Mark A Carter, KD7PHW, markcarter57@yahoo.com.
_____________________________________________________________
#include <18F67J10.h>
#device ICD=TRUE
#fuses HS,NOWDT
#use delay (clock=10000000)
#define GREEN_LED PIN_D5
#define YELLOW_LED PIN_D1
#define RED_LED PIN_D0
void delay_seconds(int n) {
      for (;n!=0;n--) {
      delay_ms (1000);
  #define delay_seconds(n)
void main () {
      while (TRUE)   {
            output_low (GREEN_LED);
            delay_seconds (5);
            output_high (GREEN_LED);
            delay_seconds (5);
            output_low (YELLOW_LED);
            delay_seconds (1);
            output_high (YELLOW_LED);
            delay_seconds (1);
            output_low (RED_LED);
            delay_seconds (5);
            output_high (RED_LED);
            delay_seconds (5);
ANY
Mark A Carter
KD7PHW
PostPosted: Wed Nov 06, 2013 3:30 pm     Reply with quote
for (;n!=0;n--) {
delay_ms (1000);
void main () {
while (TRUE) {
The reason it doesn't work is because you have defined your delay routine
out of existence. First you have the function. That's good. But then you
follow it with an empty macro declaration. Why ? The net effect is that
the compiler substitutes the empty macro for your delay function and
you can see this in the .LST file:
....................       while (TRUE)   {
....................             output_low (GREEN_LED);
00012:  BCF    TRISD.5
00014:  BCF    LATD.5
....................             delay_seconds (5);
....................             output_high (GREEN_LED);
00016:  BCF    TRISD.5
00018:  BSF    LATD.5
....................             output_low (YELLOW_LED);
0001A:  BCF    TRISD.1
0001C:  BCF    LATD.1
....................             delay_seconds (1);
....................             output_high (YELLOW_LED);
0001E:  BCF    TRISD.1
00020:  BSF    LATD.1
....................             output_low (RED_LED);
00022:  BCF    TRISD.0
00024:  BCF    LATD.0
....................             output_high (RED_LED);
00026:  BCF    TRISD.0
00028:  BSF    LATD.0
0002A:  BRA    0012
0002C:  BRA    002C
There's no delay routine. There's nothing. The only thing left is your
code to toggle the LEDs.
Comment the following line out as shown below, re-compile and see
what happens:
//  #define delay_seconds(n)
Mark A Carter
PostPosted: Wed Nov 06, 2013 4:12 pm     Reply with quote
Very Happy
Dear Mr. PCM programmer.
The commenting out of that line did fix the problem.
The three LEDs not sequence correctly.
I do have one addition question through.
How do I make my void delay_seconds(int n) {
for (;n!=0;n--) {
delay_ms (1000);
code section into a FUNCTION as per the books exercise part B request?
Thank you.
Mark A Carter, markcarter57@yahoo.com .
Mark A Carter
KD7PHW
Mark A Carter
My exercise B under the USB Master Exerise Book now working!
PostPosted: Wed Nov 06, 2013 4:37 pm     Reply with quote
Very Happy
It now works.
I also have gotten the #DEFINE function to work in the CCS book exercise.
Please see my corrected functioning code below.
#device ICD=TRUE
#fuses HS,NOWDT
#define delay_in_seconds delay_seconds
      for (;n!=0;n--) {
      delay_ms (1000);
void main () {
      while (TRUE)   {
            delay_in_seconds (5);
            delay_in_seconds (1);
Mark A Carter
KD7PHW
