Nauman Ali Khan
Joined: 26 Jun 2011 Posts: 3 Location: Karachi,Pakistan
PIC 16LF1825 in device library of CCS Compiler |
Posted: Wed Nov 06, 2013 3:38 am |
Dear All,
Device PIC16LF1825 is not available in device library of CCS Compiler PCW. What is the solution.
Thank You In advance.
Regards,
Noman _________________ NAK |
Posted: Wed Nov 06, 2013 3:49 am |
Buy a later compiler.
It has been in the compiler's device library for a long time. Quick check shows it there in all the V5 compilers. 4.141, etc.. Even back to 4.118. Not there in 4.112 though, so it was added early 2011.
Understand that the file, does not add support for a chip. The device database with the compiler has to also know about the chip, and this was updated at the same time, so you need a later compiler. |
Nauman Ali Khan
Posted: Wed Nov 06, 2013 3:51 am |
What version of compiler should i buy ? _________________ NAK |
Posted: Wed Nov 06, 2013 7:56 am |
Just buy the update. Gives you one year ability to download the latest versions of your compiler. |
micro_debugger
Posted: Wed Nov 06, 2013 9:44 am |
I used it in latest version of 4, before the 5, and there was a bug in a serial port implementation. I have not correct it, not tested even in details, just change the processor. On Monday I will have new PCB for another project with a place for the PIC16F1825 and will test it in any case with 5.013, so if you wait until mid of next week you will have more detailed info.
Warmest Regards |
Nauman Ali Khan
Posted: Thu Nov 07, 2013 1:03 am |
I got Version 5. Problem resolved. Thanks ![Smile](images/smiles/icon_smile.gif) _________________ NAK |
