Big Problem with Packed struct in Version 5.007 and 5.012
cfernandez
PostPosted: Sat Oct 12, 2013 3:18 pm     Reply with quote
I make a example I compile this code with 3 different version and all output are different:
V 4.141
Test...
0001000050000000C359000000027FD6AB5B2308547697092E14150B00000000DB00008F5C0500004A57F40200008F5C020700A4000C020D04190034000414 5C8F0000 DB0000008BA0E21BEBD62FC0F623C169000000
StSize 316
256
80
FW:15-0B LTC:3674210304 Monto:1552875520 DF:5 TxID:4099361280 C#:2 $C:1552875520 ELG:2...
V 5.007
Test...
0001000050000000C359000000027FD6AB5B2308547697092E14150B00000000DB00008F5C0500004A57F40200008F5C020700A4000C020D041900340004145C8F0000DB0000008BA0E21BEBD62FC0F623C169000000
StSize 318
256
80
FW:15-0B LTC:14352384 Monto:89952000 DF:0 TxID:49567562 C#:0 $C:117595279 ELG:0...
V 5.012
Test...
StSize 316
0
0
FW:00-00 LTC:0 Monto:0 DF:0 TxID:0 C#:2 $C:1552875520 ELG:254...
The 4.141 work ok, the news version are wrong.
This is my code, and I use a PIC24H
   UINT8    uiPtr;
   UCHAR    *sPtr;
   struct STRUCT_PACKED
        UINT32      udPOSID;
        UINT16      ulDataLGLen;
        UCHAR       sPOSLGSAMId[ 20 ];
        UINT8       uiFWVersion;
        UINT8       uiFWRelease;
        UINT8       uiNULL;
        UINT32      udLTC;
        UINT32      udMonto;
        UINT16      ulDF;
        UINT32      udTransactionID;
        UINT8       uiCommandCounter;
        UINT32      udImporteCargado;
        UINT8       uiEstadoLG;
        UCHAR       sAPDU[ 267 ];
    } stDataLG2;
   memcpy( &stDataLG2, "\x00\x01\x00\x00\x50\x00\x00\x00\xC3\x59\x00\x00\x00\x02\x7F\xD6\xAB\x5B\x23\x08\x54\x76\x97\x09\x2E\x14\x15\x0B\x00\x00\x00\x00\xDB\x00\x00\x8F\x5C\x05\x00\x00\x4A\x57\xF4\x02\x00\x00\x8F\x5C\x02\x07\x00\xA4\x00\x0C\x02\x0D\x04\x19\x00\x34\x00\x04\x14\x5C\x8F\x00\x00\xDB\x00\x00\x00\x8B\xA0\xE2\x1B\xEB\xD6\x2F\xC0\xF6\x23\xC1\x69\x00\x00\x00", 86 );
   sPtr = &stDataLG2;
   fprintf( SERIAL_DBG, "Test...\n\r" );
   for ( uiPtr = 0 ; uiPtr < 86 ; uiPtr++ )
      fprintf( SERIAL_DBG, "%02X", sPtr[ uiPtr ] );
   fprintf( SERIAL_DBG, "\n\r" );
   fprintf( SERIAL_DBG, "StSize %lu\n\r", sizeof( stDataLG2 )  );
   fprintf( SERIAL_DBG, "%lu\n\r", stDataLG2.udPOSID );
   fprintf( SERIAL_DBG, "%lu\n\r", stDataLG2.ulDataLGLen );
   fprintf( SERIAL_DBG, "FW:%02X-%02X LTC:%lu Monto:%lu DF:%lu TxID:%lu C#:%lu $C:%lu ELG:%u", stDataLG2.uiFWVersion, stDataLG2.uiFWRelease, stDataLG2.udLTC, stDataLG2.udMonto, stDataLG2.ulDF, stDataLG2.udTransactionID, stDataLG2.uiCommandCounter, stDataLG2.udImporteCargado, stDataLG2.uiEstadoLG );
   fprintf( SERIAL_DBG, "...\n\r" );
   while( TRUE )
     restart_wdt( );
__PROGRAM_MEMORY_END__:
The STRUCT_PACKED is a define for __attribute__((packed))
PostPosted: Sun Oct 13, 2013 1:00 am     Reply with quote
The 16bit PIC's _require_ int32's and int16's, to be word aligned.
Your layout:
UINT8 uiEstadoLG;
will give a problem because of this.
If you search on the forum, you will find this being discussed.
If you need the alignment (to allow the data to be used elsewhere), use:
<http://www.ccsinfo.com/forum/viewtopic.php?t=44569&highlight=word+align>
You are _assuming_ that data in a structure is placed sequentially in memory. There is no guarantee of this, except for 'entities' like arrays etc.. The optimiser either has to add an extra padding byte when the word does not align, or relocate entities to get the required alignment. Why not just initialise the structure in the declaration?. If you use the standard initialisation format, then the compiler knows which entry corresponds to which element, and moves the entries as needed. As a 'block' of data in memory, moved with memcpy, there is no such guarantee.
You'd get the same problem if you tried to do a memory move like this to the array on a PC, unless you forced this to be aligned. Beware the caveat though if you start trying to use pointers to the array...
