Strange problem with i2c slave on 16F690 [Solved]
arunb
PostPosted: Mon Sep 30, 2013 1:20 pm     Reply with quote
PCM: 3.249
MPLAB IDE: 8.60
Device: 16F690
I am trying to setup the 16F690 as an i2c slave. I used the EX_SLAVE.c code example for this. This works very well.
But when I add set_tris_a, set_tris_b, set_tris_c functions, the i2c communication stops and the 16F690 does not respond.
The same problem occurs when using enable_interrupt(INT_RDA).
The working code is given below.
#include <16F690.h>
#fuses INTRC_IO,NOWDT,PUT,NOPROTECT,NOCPD,NOBROWNOUT,NOIESO,NOMCLR,NOFCMEN
#use rs232(baud=9600,xmit=pin_b7, rcv=pin_b5,parity=n,errors)
#use i2c(SLAVE,slow,SDA=pin_b4,SCL=pin_b6,address=0xA7)
BYTE address,buffer[0x10];
#INT_RDA
void usart()
#INT_SSP
void ssp_interupt()
   BYTE incoming,state;
   state=i2c_isr_state();
   if (state<0x80)                     //Master is sending data
      incoming=i2c_read();
      if (state==1)                     //First received byte is address
         address=incoming;
      if (state==2)                     //Second received byte is data
         buffer[address]=incoming;
   if (state==0x80)                     //Master is requesting data
      i2c_write(buffer[address]);
#zero_ram
void initialise()
   setup_oscillator(OSC_INTRC|OSC_4MHZ);
//   set_tris_a(0b11111111);
//   set_tris_b(0b00101111);
//   set_tris_c(0b00110111);
//   enable_interrupts(INT_RDA);
      enable_interrupts(INT_SSP);
   initialise();
   do{
   }while(TRUE);
the problem starts when the set_tris_a, set_tris_b, set_tris_c and enable_interrupts(INT_RDA) lines are un-commented.
I am powering the 16F690 with a 3.3V supply, the pullups are 3.9K. However I don't think the problem is with the supply as the example code works very well.
Please help...
thanks
a
PostPosted: Mon Sep 30, 2013 1:33 pm     Reply with quote
#INT_RDA
void usart()
The source of the interrupt is the fact that there is a character sitting in
the UART's receive buffer. If you don't read the character (which removes
it from the buffer), it will sit there in the buffer and you will get an
interrupt over and over again. The program will appear to lock up.
To prevent this, read the character with getc() inside the #int_rda routine.
#use i2c does not want an odd slave address. Change it to an even address.
alan
PostPosted: Mon Sep 30, 2013 1:34 pm     Reply with quote
As far as I know the SDA and SCL pins should be inputs.
Regards
arunb
re
PostPosted: Mon Sep 30, 2013 1:43 pm     Reply with quote
thanks for the reply, i shall try this out.
but why does the i2c communication lock up when only the set tris functions are used (no rda interrupt).
thanks
a
PostPosted: Mon Sep 30, 2013 1:54 pm     Reply with quote
Get rid of the floating inputs. In the thread below, it is shown that floating
inputs on spare pins cause the SPI to partially fail. It could also affect i2c:
http://www.ccsinfo.com/forum/viewtopic.php?t=45371&start=15
arunb
re
PostPosted: Tue Oct 01, 2013 1:02 pm     Reply with quote
thanks for the reply, i made all the unused ports as input and pulled them high, its working well now,
thanks
a
