Gabriel
Compiler upgrade - Modbus TCP |
Posted: Wed Sep 25, 2013 7:18 pm |
Hi all, its been a while..
I'm about to purchase the PCH compiler, Due to a need of Modbus TCP.
I have purchased PCM previously, and see in my example folders SOME Modbus Tcp/IP drivers etc...
Obviously im missing the TCP/IP stack...
does PCH bring the missing drivers for modbus TCP? including the stack?
I don't need web servers or email... so as long as the stack works for modbus.. im good... i can use C18 for the rest as i do currently...
Im planing on using Olimex PIC-MAXI-WEB as hardware...
its working fine as a server with C18....
so, PCH.. is it good for Modbus TCP and does it bring the examples/Drivers?
Thanks,
G. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Gabriel
Posted: Wed Sep 25, 2013 7:51 pm |
...Screw it... i got it anyways. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Gabriel
Posted: Thu Sep 26, 2013 8:20 am |
Stack is no where to be found.... great. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Posted: Thu Sep 26, 2013 6:51 pm |
Ask CCS, they will send it to you. _________________ Google and Forum Search are some of your best tools!!!! |
Gabriel
Posted: Fri Sep 27, 2013 9:32 am |
I did, and they did!
Awesome.
... now all i need is a Modbus TCPIP example.
but I think thats my job... failing miserably so far.. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
