How can i show voltage variable(in float) to 240x128 GLCD
Posted: Wed Sep 25, 2013 6:49 am
How can i show voltage variable (in float) to 240x128 GLCD ? I am using 18f46k22. Can you send this code? Thank you. _________________ M.Emir SADE
Posted: Wed Sep 25, 2013 12:46 pm
Here on this forum we want to help you but we are not going to do your work. The task you are asking is very basic and simple. Lots of examples can be found here on this forum.
In your previous post you had problems to show anything on the LCD. Have you managed this now?
If you can write a 'hello world' text to the display, then it is a small step to display a variable integer. From there it is just another tiny step to display a float variable.
