time delay between power up and main function.
ZuLu
PostPosted: Tue Sep 17, 2013 5:44 am     Reply with quote
Hello my friends,
I have PIC18F8723 micro controller in my circuit, this MCU controls inhibit of main power supply. When MCU power supply is stand up, I could not control any ports earlier than 63msec. Minimum time delay of controlling a port in main function is 63msec as shown. In scope screen yellow signal is pin of MCU, green signal is MCU power supply.
How can i control any ports just after power up?I want to shorten this delay as soon as possible.
Fuses:
//#FUSES HS                     //Low power osc < 200 khz
#FUSES INTRC_IO                 //Internal Oscillator enabled  LEBC
#FUSES NOBROWNOUT
//!#FUSES BROWNOUT                 //brownout reset enabled    LEBC
//!#FUSES BORV42                   // 4.2'de reset olacak
#FUSES NOPUT                    //Power Up Timer enabled
#FUSES NOCPB                    //No Boot Block code protection
#FUSES MCLR                   //Master Clear pin enabled
Main function summary:
   set_tris_E(0x00);
   output_E(0x80);
Thanks.
