Help with abs() function
dbj
PostPosted: Sun Jun 01, 2014 12:55 pm     Reply with quote
Can someone please tell me what I'm doing wrong. I can't seem to get the abs() function to return the correct value - (s, t, and x are always -500). Code compiles without errors. Compiler version 5.026
#include <16F1847.H>
#device *=16
#FUSES MCLR
#FUSES NOLVP                    //No low voltage prgming
#use delay (internal=4M)
#use rs232(baud=19200,parity=N,xmit=PIN_B4,rcv=PIN_B3,bits=8,stream=PORT1)     // Tx=(PIN 10), Rx=(PIN 9)
#include <stdlib.h>
   long s = -500;
   long t = abs(s);
   long x = labs(s);
   printf("s= %Ld   t= %Ld   x= %Ld  \r\n",s,t,x);
PostPosted: Sun Jun 01, 2014 1:11 pm     Reply with quote
Read the CCS manual. It says:
unsigned -
Data is always positive. This is the default data type if not specified.
Which means you need to declare your variables as 'signed long',
to get your program to work properly.
Or, also given in the manual, you could put the compiler in ANSI mode:
#device ANSI
The manual says:
ANSI - Default data type is SIGNED
PostPosted: Sun Jun 01, 2014 2:40 pm     Reply with quote
As a further bit of explanation.
The value -500, codes as 0xFE0C.
When you write this into an unsigned int16, you store 0xFE0C, which in an unsigned variable is treated as 65036.
Feeding 65036 into abs, gives 65036 out (abs knows the types of the variables it is given).
Then taking the unsigned integer 65036, and printing this as a signed value, displays -500.
As a comment, I'd suggest getting out of the habit of using 'indeterminate' types like 'long'. Much safer to code as int16, which you then 'know' how long the value is whatever processor/compiler you are using. Even better, load stdint.h, and be really explicit, with 'uint16_t', and 'int16_t' for unsigned and signed.
dbj
PostPosted: Sun Jun 01, 2014 4:57 pm     Reply with quote
PCM - I knew it was something simple and stupid like that. I think I'll fix it by changing how I declare it. Yeah, I've read quite a bit of the manual, but it's hard to keep track of all the nuances that are so obvious to seasoned programmers.
Ttelmah - Thanks for the detailed explanation, that makes a lot of sense now. It's been about 20 yrs since the last time I did programming, and that was in assembly on a 68HC11, so not only do I have to ramp back up with how to program a microcontroller but also learn C. I'll change the code in my real program (not the test one I posted) to what you suggested.
And thanks to both of you for all your help, not only in this post, but in the dozens of other threads that I've searched through in the past few weeks.
