LCD 2x16 using PIC16F688 (LCD.C modification)
rald
PostPosted: Thu Sep 05, 2013 9:25 am     Reply with quote
Hello experts,
I have a big problem and I hope you can help me... I bought a PIC16F688, this PIC does not have a port D or B like the LCD.C library contains.
I need to connect a LCD parallel to the port A.
Des anyone know if it is possible to change the port into the library to this works with port A?
I hope someone can respond to this question...
thank you.
ezflyr
PostPosted: Thu Sep 05, 2013 9:58 am     Reply with quote
Search the code forum and use the 'Flex_LCD' driver instead of LCD.c. The Flex_LCD driver allows you the flexibility to define whatever pins you desire to connect to your LCD.
This has been discussed thousands of times on the forum....
John
