Prefekt
USB HID with more then 2 bytes |
Posted: Wed Aug 28, 2013 11:28 am |
I have tried the ex_usb_hid example. I need to transmit more then 2 bytes in both directions.
But I don't know what I must change.
In the documentation is written to change the package size, but how?
thanks
Volker |
Prefekt
Posted: Wed Aug 28, 2013 1:02 pm |
I have change this value to transmit 3 bytes...
in usb_cdc_hid.h:
0x75, 8, // Report size = 8 (bits)
0x95, 3, // Report count = 16 bits (2 bytes)
0x81, 3, // Input (Data, Var, Abs)
0x19, 1, // Usage minimum
0x29, 8, // Usage maximum
0x91, 3, // Output (Data, Var, Abs)
0xc0 // End Collection
and in the sample:
usb_put_packet(1, out_data, 3, USB_DTS_TOGGLE)
usb_get_packet(1, in_data, 3);
it works... are these all places? |
Posted: Thu Aug 29, 2013 11:25 am |
Don't change the file.
Just set the two defines:
USB_CONFIG_HID_TX_SIZE
and
USB_CONFIG_HID_RX_SIZE
_Before_ you load the HID descriptor.
Maximum value you can set is 64.
These change everything needed for you.
If undefined, they default to two (the size wanted by the demo). Otherwise your values override the settings.
Prefekt
Posted: Sat Aug 31, 2013 5:34 am |
thank for the information. I thought about this, but I was not shure.
Volker |
