Will Reeve Guest
Going back to MPLAB for ICD |
Posted: Fri May 23, 2003 5:38 am |
Is it me? I can't get the ICD in CCS to work properly. It messes up break points and doesn't seem to program the current code sometimes! I want to go back to MPLAB5.7 is there a simple .hex file I can program into a 16F876 to get it all working? I have tried IC10200.hex but it won't verify as I assume it is designed to load via a boot loader. Is there an "image" somewhere I can just flash into a blank pic?
Will
___________________________
Original Post ID: 144514696 |
Douglas Kennedy
Re: Going back to MPLAB for ICD |
Posted: Fri May 23, 2003 10:16 am |
:=Is it me? I can't get the ICD in CCS to work properly. It messes up break points and doesn't seem to program the current code sometimes! I want to go back to MPLAB5.7 is there a simple .hex file I can program into a 16F876 to get it all working? I have tried IC10200.hex but it won't verify as I assume it is designed to load via a boot loader. Is there an "image" somewhere I can just flash into a blank pic?
:=Will
Try MPL876.hex it is often found in program files\MPLAb
Original Post ID: 144514704 |
John Taylor Guest
Posted: Sat May 24, 2003 10:54 am |
I was having simillar problems with the ICD in PCWH. I finally fixed it when I got the valid fuses ([menu],[view],[valid fuses]+cut-n-paste into header as comment for reference) for the device being used and specified every fuse possible in the #fuses statement.
MPLAB makes you set the fuses in a window which works but does not allow embedding of the fuse data in the code build properly (MPLAB 6 does it the same as CCS!)
After doing this, I have had no problem with the ICD/PCWH interface.
jt
:=Will
Original Post ID: 144514724 |
Will Reeve Guest
Posted: Tue May 27, 2003 4:10 am |
<font face="Courier New" size=-1>jt,
Thanks. This had fixed it and things are working. I am more used to CCS holding my hand with automatic set-up than Microchip; but once I set all the fuses to how I used to have them in MPLAB everything seems to work. I think it would be nice to have a pane on the CCS project wizard for all the fuse options you can just tick box the ones you want. They could also fix the problem in getting PWM set-up correctly (it calculates Timer 2 incorrectly if you change the oscillator speed!) but thats another thread!
Thanks again jt,
Will
P.S. Douglas, found that file but luckily didn't have to use it. If things go wrong I might go back to MPLAP but I like some of the features on CCS now they seem to work correctly!</font>
Original Post ID: 144514773 |
