Could not start target
Pekub
PostPosted: Fri Aug 16, 2013 4:16 am     Reply with quote
I use 18F14K22. It works fine, but I can't get it to debug.
It appears:
Could not start target: The target was not halted after reset.......
I try it with ICD-U40 and ICD-U64. I also changed the processor.
Pin MCLR is connect to 5V via 33k resistor.
For ICD I use the newest software and firmware.
This is my test program:
#include <18F14K22.h>
#device ICD=TRUE
#FUSES INTRC                   //Internal RC Osc, CLKOUT on RA4
#use delay(internal=1000000)
void main(void) {
   int x;
   x=5;
   while(TRUE) {
        x++;
        x=x+2;
The problem I have seen in this forum, but I did not find solution.
PostPosted: Fri Aug 16, 2013 10:56 pm     Reply with quote
The 18F14K22 doesn't have built-in support for the ICD debugger.
You need an ICD header.
ICD Debug header for 18F14K22:
http://www.microchipdirect.com/productsearch.aspx?Keywords=AC244033
Processor Extension Pak and Header Specification:
http://ww1.microchip.com/downloads/en/DeviceDoc/51292U.pdf
The header is expensive, compared to an indivual PIC chip. If this is just
a hobby project, develop the project on a similar PIC but use one that has
built-in debug support. Then when development is done, compile the
program for your actual PIC, the 18F14K22.
Pekub
Debug 18F14K22 - solved
PostPosted: Mon Aug 19, 2013 6:59 am     Reply with quote
PIC18F14K22 is possible to debug with ICD-U64 / maybe with ICD-U40, I have not tried it /.
My problem was a bad installation program PCWHD V4.132.
It was necessary to reinstall the program PCWHD V4.132 and already it works / of course, also debugging /.
Peter
