zero2004
help in spi function |
Posted: Sun Aug 18, 2013 11:26 pm |
Hi every one
I want flip the initial spi clock state to be hi instead of low, i declare the spi function as follow
Code: | #USE SPI (MASTER, SPI1, CLOCK_HIGH=1, CLOCK_LOW=1, MODE=0, BITS=8, LOAD_ACTIVE=1, STREAM=SPI_1, MSB_FIRST)
Thanks for your help |
Posted: Mon Aug 19, 2013 12:43 am |
The mode number specifies the 'idle' (initial) state. Mode0, idles low. Modes 2 and 3 idle high.
USE SPI (MASTER, SPI1, MODE=3, BITS=8, LOAD_ACTIVE=1, STREAM=SPI_1, MSB_FIRST)
Have a look at:
<http://en.wikipedia.org/wiki/Serial_Peripheral_Interface_Bus>
Look at 'CPOL' (clock polarity), and the effect of the mode numbers on this.
zero2004
Posted: Tue Aug 20, 2013 12:50 am |
Thanks |
