Baptiste
| ccs bootloader |
Posted: Thu Jul 18, 2013 3:00 am |
I've got a problem with the CCS bootloader : I have to increase the main function size in order to add some code.
I've replaced this line :
| Code: | #org 0x40,0x98
by
| Code: | #org 0x40,0xc2
When I do that, after sending my program to the bootloader, and after doing a reset, the bootloader doesn't run.
I think that the code is overwritten by the program
I tried to change some #org constants and the aPPLI_END and APPLI_SIZE constants but the result is the same
Can anybody help me to find a solution ?
Thanks a lot |
