blacknyellow
I2C Communication Problem |
Posted: Mon Jul 22, 2013 8:24 am |
HELLO!!
I want to communicate 2 pics (16f877a) using i2c bus. Its an extremely simple code just to see if its working or not. In this code, I simply want to receive data from the slave and print it on a 2x16 LCD. However on the PROTEUS simulation i only see "FF" transferred. Here is the code for reference.
#include <16F877A.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES WRT_50% //Lower half of Program Memory is Write Protected
#use i2c(Slave,Fast,sda=PIN_C4,scl=PIN_C3,force_hw,adress=0x90)
int8 n=15,p;
#int_SSP
void SSP_isr(void)
{ int8 state,incoming;
state=i2c_isr_state();
if((state >= 0x80));
i2c_write(n);
setup_adc_ports(AN0);
setup_psp(PSP_DISABLED);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
setup_timer_2(T2_DIV_BY_1,1,1);
setup_vref(FALSE);
enable_interrupts(INT_SSP);
// TODO: USER CODE!!
MASTER
#device adc=8
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3,force_hw)
#include <flex_lcd_b bacak.c>
int8 data;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_vref(FALSE);
lcd_init();
delay_ms(50);
printf(lcd_putc,"\f");
printf(lcd_putc,"yazi=\n");
i2c_start();
i2c_write(0x91);
delay_us(50);
//i2c_write(0x05);
//delay_us(50);
//i2c_stop();
//i2c_start();
//i2c_write(0x91);
data=i2c_read(0);
i2c_stop();
printf(lcd_putc,"%d",data);
I would really appreciate if you could help |
Posted: Mon Jul 22, 2013 10:27 am |
I don't know how to make it work in Proteus. Proteus has weird things
like digital and analog pull-ups. It also may not work without the i2c
debugger turned on. I don't want to solve these problems. I only
use hardware to test i2c. The following method works with two hardware
boards (or two PICs on one board):
Use the CCS example file code, Ex_Slave.c, for the Slave PIC.
It's in this directory:
Quote: |
c:\Program Files\picc\Examples\Ex_Slave.c
Use the code in this post for the Master PIC:
http://www.ccsinfo.com/forum/viewtopic.php?t=32368&start=3
Use these connections:
+5v
> 4.7K
To <
Master PIC | To Slave PIC
SDA pin ------------------ SDA pin
(pin C4) (pin C4)
+5v
> 4.7K
To <
SCL pin ------------------ SCL pin
(pin C3) (pin C3)
To
Master PIC To slave PIC
ground ----------------- ground (Vss pins)
(Vss pins) |
--- Ground
blacknyellow
Posted: Tue Jul 23, 2013 4:04 am |
Thank you sir. Maybe i should test my code on the board |
