Addressmod problem v5.009
miro
PostPosted: Sun Jul 14, 2013 5:05 am     Reply with quote
Hi, still the issue with addressmod. See below the code and its disassembly.
"fram_wr()" has not been compiled, both reading/writing functions point to "fram_rd()" (see at the address 0x206).
#include <33FJ128GP802.h>
#device *=16
#device ADC=12
//dummy SPI
unsigned int16 spi_x( unsigned int16 data_out)
return (data_out);
// read procedure for reading n bytes from the memory starting at location addr
void fram_rd(unsigned int32 address, unsigned int8 *dat, unsigned int nbytes)
// write opcode, address
spi_x(22);
spi_x(address>>16);
spi_x(address>>8);
spi_x(address);
while (nbytes--) *dat++ = spi_x(0xAA);
//write procedure for writing n bytes to the memory starting at location addr
void fram_wr(unsigned int32 address, unsigned int8 *dat, unsigned int nbytes)
// write opcode, address, data
spi_x(33);
spi_x(address>>16);
spi_x(address>>8);
spi_x(address);
while (nbytes--) spi_x( *dat++ );
addressmod (FRAM, fram_rd, fram_wr, 0x0000, 0x0fff);
FRAM int16 sector[512];
volatile unsigned int dummy, i;
setup_oscillator( OSC_INTERNAL, 79872000);
#use delay(clock = 79872000)
   for (i=0; i<512; i++)
      sector[i] =  i;
      dummy = sector[i];
delay_ms(200);
And the disassembly:
1:                 #include <33FJ128GP802.h>
 00000  040266     goto 0x000266
2:
3:                 #device *=16
4:                 #device ADC=12
5:
6:                 //dummy SPI
7:                 unsigned int16 spi_x( unsigned int16 data_out)
8:                 {
9:                 return (data_out);
 00200  F8081A     push.w 0x081a
 00202  F90000     pop.w 0x0000
 00204  060000     return
10:                }
11:
12:                // read procedure for reading n bytes from the memory starting at location addr
13:                void fram_rd(unsigned int32 address, unsigned int8 *dat, unsigned int nbytes)
 00206  781F85     mov.w 0x000a,[0x001e++]
14:                {
15:                // write opcode, address
16:                spi_x(22);
 00208  200164     mov.w #0x16,0x0008
 0020A  8840D4     mov.w 0x0008,0x081a
 0020C  020200     call 0x000200
17:                spi_x(address>>16);
 00210  804055     mov.w 0x080a,0x000a
 00212  8840D5     mov.w 0x000a,0x081a
 00214  020200     call 0x000200
18:                spi_x(address>>8);
 00218  BFC809     mov.b 0x0809,0x0000
 0021A  784280     mov.b 0x0000,0x000a
 0021C  BFC80A     mov.b 0x080a,0x0000
 0021E  B7E00B     mov.b 0x0000,0x000b
 00220  8840D5     mov.w 0x000a,0x081a
 00222  020200     call 0x000200
19:                spi_x(address);
 00226  804045     mov.w 0x0808,0x000a
 00228  8840D5     mov.w 0x000a,0x081a
 0022A  020200     call 0x000200
20:                while (nbytes--) *dat++ = spi_x(0xAA);
 0022E  BF880E     mov.w 0x080e,0x0000
 00230  ED280E     dec.w 0x080e
 00232  E00000     cp0.w 0x0000
 00234  32000A     bra z, 0x00024a
 00236  BF880C     mov.w 0x080c,0x0000
 00238  EC280C     inc.w 0x080c
 0023A  780280     mov.w 0x0000,0x000a
 0023C  200AA4     mov.w #0xaa,0x0008
 0023E  8840D4     mov.w 0x0008,0x081a
 00240  020200     call 0x000200
 00244  784A80     mov.b 0x0000,[0x000a]
 00246  04022E     goto 0x00022e
 0024A  7802CF     mov.w [--0x001e],0x000a
 0024C  060000     return
21:                }
22:
23:                //write procedure for writing n bytes to the memory starting at location addr
24:                void fram_wr(unsigned int32 address, unsigned int8 *dat, unsigned int nbytes)
25:                {
26:                // write opcode, address, data
27:                spi_x(33);
28:                spi_x(address>>16);
29:                spi_x(address>>8);
30:                spi_x(address);
31:                while (nbytes--) spi_x( *dat++ );
32:                }
33:
34:                addressmod (FRAM, fram_rd, fram_wr, 0x0000, 0x0fff);
35:
36:                FRAM int16 sector[512];
37:
38:                volatile unsigned int dummy, i;
39:
40:                void main()
 00266  A8E081     bset.b 0x0081,#7
 00268  EFA32C     setm.w 0x032c
 0026A  23F80F     mov.w #0x3f80,0x001e
 0026C  23FFF0     mov.w #0x3fff,0x0000
 0026E  B7A020     mov.w 0x0000,0x0020
 00270  000000     nop
 00272  23F80F     mov.w #0x3f80,0x001e
 00274  23FFF0     mov.w #0x3fff,0x0000
 00276  B7A020     mov.w 0x0000,0x0020
 00278  000000     nop
41:                {
42:
43:                setup_oscillator( OSC_INTERNAL, 79872000);
 0027A  200014     mov.w #0x1,0x0008
 0027C  883A24     mov.w 0x0008,0x0744
 0027E  2003F4     mov.w #0x3f,0x0008
 00280  883A34     mov.w 0x0008,0x0746
44:                #use delay(clock = 79872000)
 0024E  E00000     cp0.w 0x0000
 00250  AF2042     btsc.b 0x0042,#1
 00252  370008     bra 0x000264
 00254  091BFB     repeat #7163
 00256  000000     nop
 00258  093FFE     repeat #16382
 0025A  000000     nop
 0025C  093FFE     repeat #16382
 0025E  000000     nop
 00260  E90000     dec.w 0x0000,0x0000
 00262  3AFFF8     bra nz, 0x000254
 00264  060000     return
45:
46:                   for (i=0; i<512; i++)
 00282  EF2802     clr.w 0x0802
 00284  804014     mov.w 0x0802,0x0008
 00286  202003     mov.w #0x200,0x0006
 00288  E11804     cp.w 0x0006,0x0008
 0028A  36000F     bra leu, 0x0002aa
47:                      {
48:                      sector[i] =  i;
 0028C  BF8802     mov.w 0x0802,0x0000
 0028E  DD0041     sl 0x0000,#1,0x0000
 00290  780280     mov.w 0x0000,0x000a
 00292  4282E0     add.w 0x000a,#0,0x000a
 00294  884045     mov.w 0x000a,0x0808
 00296  EF280A     clr.w 0x080a
 00298  208024     mov.w #0x802,0x0008
 0029A  884064     mov.w 0x0008,0x080c
 0029C  200044     mov.w #0x4,0x0008
 0029E  884074     mov.w 0x0008,0x080e
 002A0  020206     call 0x000206                 <<<<< fram_rd() SHOULD BE fram_wr()
 002A4  EC2802     inc.w 0x0802
 002A6  040284     goto 0x000284
49:                      }
50:
51:                   for (i=0; i<512; i++)
 002AA  EF2802     clr.w 0x0802
 002AC  804014     mov.w 0x0802,0x0008
 002AE  202003     mov.w #0x200,0x0006
 002B0  E11804     cp.w 0x0006,0x0008
 002B2  36000F     bra leu, 0x0002d2
52:                      {
53:                      dummy = sector[i];
 002B4  BF8802     mov.w 0x0802,0x0000
 002B6  DD0041     sl 0x0000,#1,0x0000
 002B8  400060     add.w 0x0000,#0,0x0000
 002BA  780280     mov.w 0x0000,0x000a
 002BC  884045     mov.w 0x000a,0x0808
 002BE  EF280A     clr.w 0x080a
 002C0  208004     mov.w #0x800,0x0008
 002C2  884064     mov.w 0x0008,0x080c
 002C4  200024     mov.w #0x2,0x0008
 002C6  884074     mov.w 0x0008,0x080e
 002C8  020206     call 0x000206               <<< fram_rd()
 002CC  EC2802     inc.w 0x0802
 002CE  0402AC     goto 0x0002ac
54:                      }
55:
56:                delay_ms(200);
 002D2  200C80     mov.w #0xc8,0x0000
 002D4  02024E     call 0x00024e
 002D8  FE4000     pwrsav #0
