ccs bootloader
Baptiste
ccs bootloader
PostPosted: Thu Jul 18, 2013 3:00 am     Reply with quote
I've got a problem with the CCS bootloader : I have to increase the main function size in order to add some code.
I've replaced this line :
#org 0x40,0x98
by
#org 0x40,0xc2
When I do that, after sending my program to the bootloader, and after doing a reset, the bootloader doesn't run.
I think that the code is overwritten by the program
I tried to change some #org constants and the aPPLI_END and APPLI_SIZE constants but the result is the same
Can anybody help me to find a solution ?
Thanks a lot
PostPosted: Fri Jul 19, 2013 7:55 am     Reply with quote
What is your compiler version number and which processor are you using?
My newest compiler is v4.141 and I can't find a bootloader with APPLI_END and APPLI_SIZE constants.
