RS485 example
prafulla.prolific
RS485 example
PostPosted: Tue Jun 25, 2013 8:43 am     Reply with quote
Ttelmah or any can guide to send single byte on RS485 i had gone through example but i am not clear. please guide for master to send data & how to recieve over RS485. i am very confusing. please guide me. i will appreciate him.
I m Working as PIC Programmer Fresher
ezflyr
PostPosted: Tue Jun 25, 2013 9:47 am     Reply with quote
What are you confused about? From a programming standpoint, sending and receiving over RS485 will be the same any other serial operation. The only
difference is that you must add the 'Enable' keyword to your #use rs232 statement, and specify a hardware pin to control the direction of data on
the RS485 bus. Typically, you will use a MAX485 interface IC or equivalent.
There are lots of RS485 related threads here on the forum.....
John
