Help For Zero Detect & Phase Angle Control
prafulla.prolific
PostPosted: Tue Jun 11, 2013 5:50 am     Reply with quote
I am using 16F873A Controller for Phase Control & Zero Detect. Using Optocoupler EL817D, I have read Zero detect and output Pulse given to MOC3023 which connect between TRIAC Gate & Microcontroller. I have written Sample Program for low Phase Level.my code as
Pin Used for functioning as
Pin 26-RB5- Zero Cross Detect.
Pin 4-RA2- Phase Drive _Pulses to MOC3023.
#define MINIMUM_FIRING_ENGLE   115
#define MAXIMUM_FIRING_ENGLE   245
void initialize_ports(void);
void initialize_variables(void);
unsigned int8 fire_on_delay;
unsigned int8 firing_angle;
unsigned int1 TRAIC_GATE;
#int_RB
void  RB_isr(void)                           // Zero Cross Detect _ to Pin RB5
      TRAIC_GATE=1;
      set_timer0(firing_angle);
      enable_interrupts(INT_TIMER0);               //Enable timer0 interrupt
#int_TIMER0
void  TIMER0_isr(void)
   disable_interrupts(INT_TIMER0);               //disable timer0 interrupt
   if(TRAIC_GATE)
      output_low(PIN_A2);
      TRAIC_GATE=0;
      set_timer0(fire_on_delay);
   else if(!TRAIC_GATE)
      output_high(PIN_A2);
      TRAIC_GATE=1;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(SPI_SS_DISABLED);
//   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_128);
   setup_timer_1(T1_DISABLED);
   enable_interrupts(INT_RB);
//   setup_timer_2(T2_DIV_BY_16,255,1);
   setup_vref(FALSE);
   initialize_ports();
   initialize_variables();
// enable_interrupts(INT_TIMER0);
   firing_angle = 142.61;
   fire_on_delay= 238.39;
   // TODO: USER CODE!!
   output_low(PIN_A0);
   output_low(PIN_A1);
   output_high(PIN_A2);            \\Output to TRIAC Gate_ Through MOC3023
   output_float(PIN_A3);
   output_float(PIN_A4);
   output_float(PIN_A5);
   output_float(PIN_B5);
   TRAIC_GATE=0;
Previously i had written code for 16F684. It is working but using same logic it can't work. Can anyone help me? What's wrong in my logic or in program?
I m Working as PIC Programmer Fresher
asmboy
PostPosted: Tue Jun 11, 2013 5:58 am     Reply with quote
1-care to post the schematic of your circuit?
2- what were you expecting by trying to set timers to FLOAT values ?
3- what you posted is horribly INCOMPLETE - and nearly impossible to analyze. for instance : what PIC - ? what CLOCK/use_delay??
4- POST A PROGRAM that COMPILES , and is complete and shows your issue !!!
then we have this:
fire_on_delay= 238.39; // odd assignment for an INT8 !!
// and in the isr
also
you never change your params for the above either ??
and
it is not useful to disable and re-enable ints INSIDE your ISR.
you have quite the mess and it is hard to know where to start really
prafulla.prolific
PostPosted: Tue Jun 11, 2013 12:11 pm     Reply with quote
i am attaching my circuit so it will clear
[img] https://mail-attachment.googleusercontent.com/attachment/?ui=2&ik=f325818cf4&view=att&th=13f346d47201d51c&attid=0.1&disp=inline&realattid=f_hhtef2290&safe=1&zw&saduie=AG9B_P860GTqRQvM9PqRFTufawT1&sadet=1370974177500&sads=DDnjZWZiybcsOPOC3QBYq-BDNlE&sadssc=1 [/img]
i am trying to attach but not shown.
PostPosted: Tue Jun 11, 2013 1:34 pm     Reply with quote
It is working
There is no way this code worked before.
That's because this #int_rb code is wrong. The #int_rb interrupt occurs
when an i/o pin changes state. The "changed state" condition is latched.
As long as the latch (inside the PIC) is set, the #int_rb interrupt will
continuously occur. To clear the latch, you have to read PortB. However
if you use the input_b() function to read the port, it will normally change
all of PortB into an input port. If some pins on PortB are used for outputs,
this setup will be changed, and those output pin won't work. So it's better
to read PortB directly.
#int_RB
      TRAIC_GATE=1;
The code below shows how to read PortB without changing the TRIS,
to clear the "change condition" for #int_rb:
#int_RB
#byte PortB = getenv("SFR:PortB")
int8 temp;
temp = PortB;
TRAIC_GATE=1;
Also, another little minor thing. The device is called a "Triac". You spelled
it wrong in "TRAIC_GATE". Why is this important ? It's because C
programming and electronics requires attention to detail. Every little
detail is or can be important. If you miss something so simple as spelling,
how can you do a complex program with hundreds of details that must all
be correct ?
This line below is from the CCS Wizard. It's not correct. It's bug in the
wizard. Delete that line. It's not needed. SPI is disabled on power-up.
The code below shows that you have not learned the C language.
You are putting a floating number into a "unsigned 8 bit integer".
An 'int8' can only hold numbers from 0 to 255. How can it possibly
hold 142.61 ? I will be very clear. When an experienced programmer
sees this type of mistake, he groans. You must learn basic C
programming before you write a complicated program.
prafulla.prolific
PostPosted: Wed Jun 12, 2013 12:57 am     Reply with quote
Dear PCM Programmer I have change interrupt PORTB Change as given by your code
#int_RB
int8 temp;
temp = PortB;
TRAIC_GATE=1;
But not effect i had check zero detect pulse on CRO it shows 7ms ON & 3ms OFF pulses of 100Hzs, But on Outputside it shows 25us pulses also not stable. i am so confuse.
I am also posting previous code for 16F684 as
#include <16F684.h>
#device adc=10
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES PROTECT                  //Code protected from reads
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOCPD                    //No EE protection
#FUSES NOPUT                    //No Power Up Timer
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#use delay(clock=8000000)
#BYTE PORTA = 0x05
#BYTE PORTC = 0x07
void read_pot_position(void);
void shift_buff(void);
void shift_adc_buff(void);
unsigned int8 buff[50]={};
unsigned int8 temp_port_a;
#int_RA
void  RA_isr(void)
      TRAIC_GATE=1;
      temp_port_a = PORTA;
#int_TIMER0
   if(TRAIC_GATE)
      output_low(PIN_C2);
      TRAIC_GATE=0;
      output_high(PIN_C2);
      TRAIC_GATE=1;
   setup_adc_ports(sAN5|VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_64);
   enable_interrupts(INT_RA);
   setup_oscillator(OSC_8MHZ);
   setup_vref(FALSE);
   initialize_ports();
      read_pot_position();
   output_float(PIN_A0);
   output_float(PIN_A1);
   output_float(PIN_A2);
   output_high(PIN_C0);
   output_float(PIN_C1);
   output_float(PIN_C3);
   output_float(PIN_C4);
   output_float(PIN_C5);
   unsigned int8 i;
   firing_angle = MINIMUM_FIRING_ENGLE;
   TRAIC_GATE=0;
   for(i=0;i<50;i++)
      buff[i]=firing_angle;
   unsigned int32 adc_output_data;
   unsigned int16 i;
   unsigned int8 temp_data;
   unsigned int8 fire_data;
//   unsigned int16 read_data;
   set_adc_channel(5);
   adc_output_data = 0;
   for(i = 0; i <100; i++)
      adc_output_data += read_adc(ADC_START_AND_READ);
      temp_data=(unsigned int8)(adc_output_data/927.2);
      if(temp_data > 11)
         fire_on_delay=(unsigned int8)(266 - temp_data);
         fire_on_delay=255;
      fire_data = MINIMUM_FIRING_ENGLE + temp_data;
      firing_angle =buff[0];
   if(temp_data <=1)
      firing_angle =0;
   shift_buff();
   buff[49]=fire_data;
   unsigned int8 j;
   for(j=0;j<49;j++)
       buff[j]=buff[j+1];
its working with same hardware but PIC IC Change.I am Confuse please give any hint i will also try.
[img]http://postimg.org/image/yjr4nsi1r/[/img]
asmboy
PostPosted: Wed Jun 12, 2013 9:54 am     Reply with quote
i lack confidence in the zero cross detector to actually show you the true
zero without, ongoing, varying ERROR.
1:
for true random firing angle - C8 may be too large for "low angle" , reliable firing. i would even OMIT it....
2:
using an OPTO coupler is dramatically less reliable than transformer coupling,
in my own design experience of such matters.
this is not to say i am SURE OPTO's can't work -
merely that on casual inspection, the circuit you show is susceptible to several kinds of error and drift, -
that a transformer + comparator circuit - would be more immune to .
prafulla.prolific
PostPosted: Mon Jun 24, 2013 1:55 am     Reply with quote
ya now i modify my code and after zero detect interrupt occur start timer0 for delay for phase angle and give pulse (High) to MOC3021 and after 7ms from zero detect again pulse going to LOW to MOC3021 it work properly. Timer0 Delay increase from 1ms to 7ms then light intensity varies.
