Problem with tcp/ip stack
noname3020
PostPosted: Fri Jun 21, 2013 8:52 pm     Reply with quote
I'm using the tcp/ip stack with example 13b.c
I'm using pic18f4520 to send data from rs232 to to the TCP_client.exe. But i don't know why my board only send data for about 30s then it did not continue sending. i could still ping to my board but the TCP_client.exe didn't receive anything.
When I pressed disconnect and then pressed connect again in the application TCP_client.exe, or when I reset my board, the data was started sending. But after about 30s, my problem happen again.
void MyTCPTask() {
   static TICKTYPE lastTick[NUM_LISTEN_SOCKETS];
   static TCP_SOCKET socket[NUM_LISTEN_SOCKETS]={INVALID_SOCKET};
   static enum {
      MYTCP_STATE_NEW=0, MYTCP_STATE_LISTENING=1,
      MYTCP_STATE_CONNECTED=2, MYTCP_STATE_DISCONNECT=3,
      MYTCP_STATE_FORCE_DISCONNECT=4
   } state[NUM_LISTEN_SOCKETS]={0};
   static NODE_INFO remote[NUM_LISTEN_SOCKETS];
   TICKTYPE currTick;
   char c;
   int8 i;
   currTick=TickGet();
   for (i=0;i<NUM_LISTEN_SOCKETS;i++) {
      switch (state[i]) {
         case MYTCP_STATE_NEW:
            socket[i]=TCPListen(EXAMPLE_TCP_PORT);
            if (socket[i]!=INVALID_SOCKET) {
               state[i]=MYTCP_STATE_LISTENING;
               //sprintf(&lcd_str[i][0],"LISTENING");
            else {
               //sprintf(&lcd_str[i][0],"SOCKET ERROR");
         case MYTCP_STATE_LISTENING:
            if (TCPIsConnected(socket[i])) {
               state[i]=MYTCP_STATE_CONNECTED;
               //sprintf(&lcd_str[i][0],"CONNECTED!");
               lastTick[i]=currTick;
         case MYTCP_STATE_CONNECTED:
               if (TickGetDiff(currTick,lastTick[i]) > ((int16)TICKS_PER_SECOND * 300)) {
                  state[i]=MYTCP_STATE_DISCONNECT;
                  //sprintf(&lcd_str[i][0],"TIMEOUT");
               else {
                  if (TCPIsGetReady(socket)) {
                     while (TCPGet(socket, &c)){
                        //lcd_str[which][i++]=c;
                        //if (i>=20) {i=19;}
                        //lcd_str[which][i]=0;
                  for (j=0;j<40;j++) if (TCPIsPutReady(socket[i])) TCPPut(socket[i],data_u[j]);
                  TCPFlush(socket[i]);
            else {
               //sprintf(&lcd_str[i][0],"DISCONNECTED");
               state[i]=MYTCP_STATE_FORCE_DISCONNECT;
         case MYTCP_STATE_DISCONNECT:
            if (TCPIsPutReady(socket[i])) {
            else if (TickGetDiff(currTick, lastTick[i]) > (TICKS_PER_SECOND * 10)) {
         case MYTCP_STATE_FORCE_DISCONNECT:
            TCPDisconnect(socket[i]);
void main(void) {
   enable_interrupts(INT_RDA);
   enable_interrupts(INT_EXT);
   enable_interrupts(INT_EXT1);
   enable_interrupts(INT_EXT2);
   MACAddrInit();
   IPAddrInit();
   StackInit();
   while(TRUE) {
      StackTask();
      MyTCPTask();
Please help me,
Thanks,
oxo
PostPosted: Sat Jun 22, 2013 2:48 am     Reply with quote
Looks like your DHCP lease is expiring.
You need to call DHCPTask() regularly.
noname3020
PostPosted: Sun Jun 23, 2013 3:45 am     Reply with quote
The original example has defined not to use DHCP. It only used ICMP, ARP and TCP. And it set the default IP address.
#define STACK_USE_ICMP  1
#define STACK_USE_ARP   1
#define STACK_USE_TCP   1
void IPAddrInit(void) {
   //IP address of this unit
   MY_IP_BYTE1=192;
   MY_IP_BYTE2=168;
   MY_IP_BYTE3=1;
   MY_IP_BYTE4=50;
   //network gateway
   MY_GATE_BYTE1=192;
   MY_GATE_BYTE2=168;
   MY_GATE_BYTE3=1;
   MY_GATE_BYTE4=1;
   //subnet mask
   MY_MASK_BYTE1=255;
   MY_MASK_BYTE2=255;
   MY_MASK_BYTE3=255;
   MY_MASK_BYTE4=0;
I saw at the function "TCPPut" in the "tcp.c" that the "RemoteWindow" decrease to 0 over time. When it reach 0, the function "TCPPut" won't put anything to transmit. But i didn't see anywhere increase or update the "RemoteWindow". Did i omit somewhere and is that the ploblem?
BOOL TCPPut(TCP_SOCKET s, BYTE byte)
   SOCKET_INFO* ps;
   WORD tempCount;
   ps = &TCB[s];
   // Make sure that the remote node is able to accept our data
   if(ps->RemoteWindow == 0)
      return FALSE;
   if(ps->TxBuffer == INVALID_BUFFER)
      ps->TxBuffer = MACGetTxBuffer(FALSE);
      // Check to make sure that we received a TX Buffer
         return FALSE;
      ps->TxCount = 0;
      IPSetTxBuffer(ps->TxBuffer, sizeof(TCP_HEADER));
   ps->Flags.bIsTxInProgress = TRUE;
   MACPut(byte);
   ps->RemoteWindow--;
   tempCount = ps->TxCount;
   tempCount++;
   ps->TxCount = tempCount;
   if(tempCount >= MAX_TCP_DATA_LEN)
      TCPFlush(s);
   return TRUE;
