PIC 18F4550 USB on Windows 2008 Server
Prefekt
PostPosted: Thu May 30, 2013 2:14 am     Reply with quote
I have tried to connect a PIC 18F4550 with USB to an Windows 2008 server. The system can't find the PIC!
On my Windows7 Pc, it's working fine. Any Ideas? There a special drivers?
I thougt Win7 and 2008 Server has the same kernel, driver and so on!
thanks
Volker
PostPosted: Thu May 30, 2013 6:19 am     Reply with quote
Has run OK on W2008 server for me.
Possible things:
Some USB3 implementations give reverse compatibility problems. What chipset?.
Does anything happen?. Even without a driver, the device should be listed in device manager, with a ?.
Security is the most likely problem. On servers it is common to lockdown the machine so a 'user' can't install any hardware. Anything third party attached is a potential security breach. You can set the group policy settings to prevent drivers from being installed.
I'd suspect the last is the most likely. I set up server installs like this out of the box, so _only_ the administrator can add hardware.
Prefekt
PostPosted: Wed Jun 05, 2013 2:42 am     Reply with quote
Thanks for the answer.
The device is listed in the device manger as unknown Device '?'.
Do you have a link to the correct driver?
thanks Volker
PostPosted: Wed Jun 05, 2013 2:56 am     Reply with quote
Comes with the compiler.
'Drivers' directory of the complier, 'NT,2000,XP,VISTA,7' subdirectory.
cdc_NTXPvista.inf
In device manager, select the device, say 'update driver', and point it at this file.
Prefekt
PostPosted: Thu Jun 06, 2013 10:49 am     Reply with quote
it seems to be a general problem...
I have the PIC in a PC desktop the USB is connected and the power is connected to a power supply output.
Sometimes the PIC will not be identified from windows after a boot.
The problem seem, that the power is coming up, before the USB on board is ready.
Any Idea what I can do?
PostPosted: Thu Jun 06, 2013 11:24 am     Reply with quote
Shouldn't matter at all.
Provided the device is correctly using the connection sense pin, you can have it powered before or after the PC, and it'll connect fine. I have both devices that are switched on/off while the PC is running, and PC's that are switched on/off while the PIC is running, without problems.
If a device has it's own power, the USB 'spec', _requires_ that connection sense is used. It is (unfortunately) a common error, to not use this.
Prefekt
PostPosted: Tue Jun 11, 2013 10:38 am     Reply with quote
I have deinstall all USB driver from the pc and the plug the pic on. So I could install the new driver and I works now.
