sirc ir receiver
moneeb
sirc ir receiver
PostPosted: Wed Jun 05, 2013 3:41 am     Reply with quote
hi
m building a multi channal remote control using sirc 12 bit protocol.... doing every thing right but m not able to get the result :/
m posting my code below plz give it a look
#include <16f877A.h>
#fuses HS,NOWDT,NOCPD,NOPROTECT,PUT,NOBROWNOUT
#use delay(clock=4M)
#use fast_io(A)
#use fast_io(B)
#zero_ram
#define one_min 1450               //no of counts to safely detect bit1
#define one_max 2200               //optimal @4 MHz is 1800
#define zero_min 600               //no of counts to safely detect bit0
#define zero_max 1440               //optimal @4 MHz is 1200
#byte portb=0x06
#byte portc=0x07
#byte portd=0x08
#bit led_4=portb.4
#bit led_5=portb.5
#byte PIR1=0x0c
#bit  ccp1f=PIR1.2
int16 fall;            // variable to save the period of space
int16 rec[12]={0,0,0,0,0,0,0,0,0,0,0,0};   // array to save the received code
int16 code1[12]={0,0,0,0,0,0,0,1,0,0,0,0};
int16 code2[12]={1,0,0,0,0,0,0,1,0,0,0,0};
int16 code3[12]={0,1,0,0,0,0,0,1,0,0,0,0};
int16 code4[12]={1,1,0,0,0,0,0,1,0,0,0,0};
int16 code5[12]={0,0,1,0,0,0,0,1,0,0,0,0};
int one=0,zero=0,start=0;
int ledz,ledo;
int i=0,n;
int8 but1=0;
int8 but2=0;
int8 but3=0;
int8 but4=0;
int8 but5=0;
#int_ccp1            // interrept of falling edge
void ccp1_int()         // start the interrept rountain
   fall=ccp_1;
   setup_timer_1(t1_disabled);
//   if ((start_max>fall)&&(fall<start_min))
//      start+=1;
    if((fall<zero_max)&&(fall>zero_min))
         zero+=1;
         ledz=1;
     if((one_max>fall)&&(fall>one_min))
         one+=1;
         ledo=1;
///////////////////////////////////////////recording values/////////////////////////////////////////////////
      if((zero==1)||(one==1))      // if one or zero received, save it in rec array
            if(zero==1)
                rec[i]=0;
                  i++;
                  zero=0;
            if(one==1)
               rec[i]=1;
               i++;
               one=0;
///////////////////////////////////////////checking of codes///////////////////////////////////////////////
if (i==12)
   start=0;
   i=0;
            for(n=0;n<=11;n++)
                  if (code1[n]== rec[n])
                     but1++;
                   if (code2[n]== rec[n])
                     but2++;
                  if (code3[n]== rec[n])
                     but3++;
                  if (code4[n]== rec[n])
                     but4++;
                  if (code5[n]== rec[n])
                     but5++;
/////////////////////////////////////making corrosponding outputs//////////////////////////////
//////////////////////////////////////// button 1 conditions///////////////////////////////////
   if (but1==12)
            output_high(PIN_D0);
//////////////////////////////////////// button 2 conditions///////////////////////////////////
   if (but2==12)
            output_high(PIN_D1);
//////////////////////////////////////// button 3 conditions///////////////////////////////////
   if (but3==12)
            output_high(PIN_D2);
//////////////////////////////////////// button 4 conditions///////////////////////////////////
   if (but4==12)
         if (led_4==1)
            output_low(PIN_B0);
            output_high(PIN_B0);
//////////////////////////////////////// button 5 conditions///////////////////////////////////
   if (but5==12)
         if(led_5==1)
         output_low(PIN_B1);
         output_high(PIN_B1);
but1=0;
but2=0;
but3=0;
but4=0;
but5=0;
goto again;
again:
      ccp1f=0;
      set_timer1(0);
      fall=0;
   set_tris_b(0x00);   //set portb as output
   set_tris_d(0x00);   //set portb as output
   set_tris_c(0x0f);   // set 4-portc as input
   portb=0x00;
   portd=0x00;
   portc=0x00;
   ledz=0;
   ledo=0;
   set_timer1(0);
      setup_ccp1(ccp_capture_fe);   // capture the Rising edge
      ext_int_edge( H_TO_L );
      setup_timer_1(t1_div_by_1); // start timer1
     clear_interrupt(int_ccp1);
      enable_interrupts(int_ccp1);
      enable_interrupts(global);
Mike Walne
PostPosted: Wed Jun 05, 2013 7:07 am     Reply with quote
Reduce your code to something like 10 lines which illustrate the problem.
Also tell what is wrong, and you may get some help.
I can't even start.
Mike
PostPosted: Wed Jun 05, 2013 7:18 am     Reply with quote
Obvious comment, without looking very far, you don't want to be doing almost (if any) of the instructions you have in your 'main' loop, in a loop. Most have side effects (for instance setting up the timer1 prescaler clears it at the same time), so they will prevent the interrupt code for having any hope of working.
ext_int_edge, does nothing since you are not using int_ext.
Once the ccp edge is set, it remains set.
You don't want to be clearing the interrupt in the loop.
etc. etc...
moneeb
PostPosted: Thu Jun 06, 2013 5:59 am     Reply with quote
ok..
i think i am getting some trouble in defining the time periods or calling of the interrupt and also in the main program..
#use fast_io(A)
#use fast_io(B)
#zero_ram
and in this isr routine
   fall=ccp_1;
      start+=1;
         zero+=1;
         ledz=1;
         one+=1;
         ledo=1;
      if(((zero==1)||(one==1))&&(start=1))      // if one or zero received, save it in rec array
            if(zero==1)
                rec[i]=0;
                  i++;
                  zero=0;
            if(one==1)
               rec[i]=1;
               i++;
               one=0;
PostPosted: Thu Jun 06, 2013 6:05 am     Reply with quote
I googled 'sirc 12 bit protocol' and the 4th hit is right here in this forum !
Working code,so author says,
I'd looked at it, see how close it is to what you require.There may be some timing issues, but should really help you with your project.
hth
jay
moneeb
PostPosted: Thu Jun 06, 2013 7:06 am     Reply with quote
i also think that the problem lies with in the timing issue :/
