Help a code example for read write data eeprom on PIC18F
tienchuan
PostPosted: Sun May 26, 2013 9:00 pm     Reply with quote
Dear all
I'll try to write and read a byte into internal eeprom on PIC18F4680
The read data result is 00
There are 2 slave function on my project
1. Write eeprom
         if (check_link_pc == 1)
            gettime_ds1307 ();
            delay_ms (1) ;
            printf ("Run time: %02X:%02X:%02X\r\n", hour, min,sec) ;
            delay_ms(10);
               write_eeprom(0xF00000,0xaa);
               delay_ms(10);
               write_eeprom(0xF00005,0xbb);
               delay_ms(10);
2. Read eeprom
         if (check_restore_pc == 1)
         printf("Sending....\n");
         unsigned int8 temp_a=read_eeprom(0xF00000);
         delay_ms(10);
         printf("%d",temp_a);
         unsigned int8 temp_b=read_eeprom(0xF00005);
         delay_ms(10);
         printf("%d",temp_b);
         check_restore_pc=0;
I used CCS C ver 4.140
and further, i want to manager address of eeprom by variable int16 to perform for() function to read data eeprom as fast.
Pls show me way to fix it.
Thanks all.
Begin Begin Begin !!!
PostPosted: Sun May 26, 2013 9:25 pm     Reply with quote
Download the CCS manual and look
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
Look at the examples of code on page 62 (page 74 in the Acrobat
reader). Does it show 0xF00000 as the address ? No. It shows
values starting at 0.
Also, where does the manual say you need to add a 10 ms delay
after the write_eeprom() function ? It doesn't say that.
tienchuan
PostPosted: Sun May 26, 2013 10:00 pm     Reply with quote
Thank you.
I change my code following on this example but the result is no change, is still 00.
            gettime_ds1307 ();
            delay_ms (1);
            printf ("Run time: %02X: %2X: %02X\r\n", hour, min, sec) ;
            delay_ms (10) ;
            write_eeprom (0x0, 0x0A) ;
            //delay_ms (10) ;
            write_eeprom (0x5, 0x0b) ;
            //delay_ms (10) ;
            printf ("Saved EEPROM") ;
            check_link_pc = 0;
         // GOI LAI DU LIEU KHI MAT KET NOI CHO PC
            printf ("Sending....\n") ;
            temp_a = read_eeprom (0x0) ;
            temp_b = read_eeprom (0x5) ;
            //printf (" %d", temp_a) ;
            putc(temp_a);
            //printf (" %d", temp_b) ;
            putc(temp_b);
            check_restore_pc = 0;
Please show me way to fix it.
Thank you.
PostPosted: Sun May 26, 2013 10:23 pm     Reply with quote
Run a simple eeprom test program like this:
http://www.ccsinfo.com/forum/viewtopic.php?t=17590&start=1
tienchuan
PostPosted: Sun May 26, 2013 10:34 pm     Reply with quote
thanks PCM
But the result is still 00
The result printf on this terminal screen:
Wrote 0x55 to eeprom address 0
Read 00
Wrote 0xAA to eeprom address 0
Read 00
Done
PostPosted: Sun May 26, 2013 10:37 pm     Reply with quote
Are you testing this in real hardware or is this a simulation ?
I just installed vs. 4.140 and ran the program on an 18F4580 (it's in the
same PIC family as an 18F4680) and it worked perfectly. I ran it on
a PicDem2-Plus board (non-Rohs version, red board).
Start
Read 55
Read AA
Done
Here is the test program:
#include <18F4580.h>
#use delay(clock = 20M)
#use rs232(baud = 9600, xmit=PIN_C6, rcv = PIN_C7, ERRORS)
printf("Start\n\r\n\r");
write_eeprom(0, 0x55);
printf("Wrote 0x55 to eeprom address 0\n\r");
printf("Read %X\n\r", read_eeprom(0));
printf("\n\r");
write_eeprom(0, 0xAA);
printf("Wrote 0xAA to eeprom address 0\n\r");
printf("\n\rDone\n\r");
tienchuan
PostPosted: Sun May 26, 2013 11:00 pm     Reply with quote
Thanks PCM
I tested on real hardware, I think have a problem with eeprom?
I tried replace new pic and result is ok.
Thanks great Smile
PostPosted: Mon May 27, 2013 5:03 am     Reply with quote
One obvious comment, is "what sets 'check_link_pc' back to zero"?.
If it remains '1' for any time at all, the EEPROM will be destroyed. Every time you write to the EEPROM cell, you use a 'life'. Since a write takes typically 4mSec, and the cell write life is warranted as 100K cycles, you could potentially kill the EEPROM in just 400 seconds.....
tienchuan
PostPosted: Tue May 28, 2013 6:02 am     Reply with quote
Thanks u,Ttelmah
I'm writing a first code to test internal eeprom.
Normal, check_link_pc flag is zero, when it controlled by PC, it set to one.
Main Programme will perform task and clear it, so that I think I only work when PC request,normal it don't work as you think Smile
Thanks u.
PostPosted: Tue May 28, 2013 7:52 am     Reply with quote
Seriously, that is dangerous. The code doing the writing, should clear the flag as soon as the write is done. Otherwise it only takes a little error, for the EEPROM to be killed. Think about it like having a the return spring on the throttle on your car. When you let go, it closes _itself_.
