aztech
usb keyboard |
Posted: Sun May 05, 2013 4:01 pm |
Hi.
I'm working on usb keyboard with 18f2550.
I can send computer any character. And I want to control 'caps lock' buton on or off. But I dont know how I can..
#include <18F2550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
//leds ordered from bottom to top
#DEFINE LED1 PIN_A5 //green
#define LED2 PIN_B4 //yellow
#define LED3 PIN_B5 //red
#define LED_ON(x) output_high(x)
#define LED_OFF(x) output_low(x)
//see section below labeled USB_CABLE_IS_ATTACHED
//#define PIN_USB_SENSE PIN_B2
//#define HW_ADC_CONFIG ADC_CLOCK_INTERNAL
//#define HW_ADC_CHANNEL 0
//#define HW_ADC_PORTS AN0
#include <pic18_usb.h> //Microchip PIC18Fxx5x hardware layer for usb.c
#include <usb_desc_keyboard.h> //USB Configuration and Device descriptors for this UBS device
#include <usb.c> //handles usb setup tokens and get descriptor reports
// usb_debug_task()
// When called periodically, displays debugging information over serial
// to display enumeration and connection states. Also lights LED2 and LED3
// based upon enumeration and connection status.
void usb_debug_task(void)
static int8 last_connected;
static int8 last_enumerated;
int8 new_connected;
int8 new_enumerated;
new_connected=usb_attached();
new_enumerated=usb_enumerated();
last_connected=new_connected;
last_enumerated=new_enumerated;
void dongu(void)
static int8 tx_msg[7]={0,0,0,0,0,0,0};
static int8 leds;
tx_msg[2]=0;
usb_put_packet(1,tx_msg,sizeof(tx_msg),USB_DTS_TOGGLE);
delay_ms(5);
tx_msg[2]=30;
delay_ms(5);
void usb_keyboard_task(void)
static int8 leds;
int a=0;
if (input(PIN_A4))
int i;
for (i=0;i<10;i++)
if(input(PIN_A4))
tx_msg[2]=26;
delay_ms(20);
usb_put_packet(1,tx_msg,sizeof(tx_msg),USB_DTS_TOGGLE); //w
tx_msg[2]=21;
delay_ms(60);
usb_put_packet(1,tx_msg,sizeof(tx_msg),USB_DTS_TOGGLE); //r
tx_msg[2]=0;
delay_ms(60);
usb_put_packet(1,tx_msg,sizeof(tx_msg),USB_DTS_TOGGLE);//boş
tx_msg[2]=21;
delay_ms(20);
tx_msg[2]=31;
delay_ms(20);
usb_put_packet(1,tx_msg,sizeof(tx_msg),USB_DTS_TOGGLE);//2
dongu();
if (!input(PIN_A4))
tx_msg[2]=0;
delay_ms(10);
//receive NUM LOCK, CAPS LOCK, etc LED status from PC.
//we won't do anything with it.
if (usb_kbhit(1))
usb_get_packet(1, &leds, 1);
//HW_INIT();
usb_init_cs();
while (TRUE)
usb_task();
usb_debug_task();
if (usb_enumerated())
usb_keyboard_task();
delay_ms(10);
Anybody can help me ? Thanks |
Posted: Mon May 06, 2013 12:15 am |
Look at ex_usb_keyboard.c, which has the full list of values for this byte. 0x39, is caps lock on.
aztech
Posted: Mon May 06, 2013 2:11 am |
Ttelmah wrote: | Look at ex_usb_keyboard.c, which has the full list of values for this byte. 0x39, is caps lock on.
Telmah thanks your answers. I studied ex_usb_keyboard.c but I couldn't .
I think I have tou use this code;
Code: | //receive NUM LOCK, CAPS LOCK, etc LED status from PC.
if (usb_kbhit(1))
But I'm beginner usb and ccs protocol.
I want to 'if caps lock on' my pic sent only " b" character . Can you write this code ?
thanks. |
Posted: Mon May 06, 2013 4:07 am |
The caps lock key, is a key, just like any other.
It's scancode, is 0x39. When it is pressed, you just send this scancode to the PC. Nothing more is needed.
The LED's are a separate thing. When the caps lock key is pressed, the PC sets the bit in the LED field, corresponding to 'CAPS LOCK ON'. So you can read the LED value sent back by the PC if you require, and set a suitable LED on your keyboard. However you don't have to do anything if your unit does not want to. This is the approach used by the demo code. The bits in the LED field are:
BIT0 = NUM LOCK
BIT1 = CAPS LOCK
BIT2 = SCROLL LOCK
So if you want an LED on your keyboard to reflect that 'caps lock is on', you then need to test bit1 in the leds value returned.
aztech
Posted: Mon May 06, 2013 5:37 am |
Ttelmah wrote: | The caps lock key, is a key, just like any other.
BIT0 = NUM LOCK
BIT1 = CAPS LOCK
BIT2 = SCROLL LOCK
thank you very much. |
