ELM402 rotary decoder software emulator
Post new topic   Reply to topic    CCS Forum Index -> Code Library
silelis
PostPosted: Mon Sep 26, 2016 1:06 pm     Reply with quote
Hello, I have spent some time on ELM 402 rotary decoder software emulator.
There were 2 reasons.
First of all the ELM402 is hard to buy.
Second that this chip in retail sales costs 8 Canadian dollars.
The code I post is written to PIC12f629 and it makes this microcontroller 1:1 ELM402 replacement.
Have fun. ;-)
//main.h
#include <12F629.h>
#use delay(internal=4000000)
#FUSES nomclr
#define signal_output      // only one should be defined signal_output or UART
//#define UART             // only one should be defined signal_output or UART
#ifdef UART
   #use rs232(baud=9600,parity=N,xmit=PIN_A0,rcv=PIN_A1,bits=8,stream=PORT1)
//#define debug_slower
#define Output_invert      PIN_A2      // If GND then output stable state is GNG
#define Pulse_Width        PIN_A3      // If GND then output pulse time is short
#define signal_B           PIN_A4
#define signal_A           PIN_A5
#ifdef signal_output
   #define encoder_UP      PIN_A0
   #define encoder_DOWN    PIN_A1
/* ELM402 configuration */
#define debounce_time      5500        //us  -->   5,5 ms
#define pulse_time_short   200         //us  -->   0,2 ms
#define pulse_time_width   2000      //us  -->   2 ms
//main.c
#include <main.h>
int OLD_states;
int NEW_states;
void debounce_inputs(void)
   unsigned int16 COUNT_TARGET = (unsigned int16) (debounce_time/1000)+1;
   unsigned int16 count_low_signal_A=0;
   unsigned int16 count_high_signal_A=0;
   unsigned int16 count_low_signal_B=0;
   unsigned int16 count_high_signal_B=0;
   do
      delay_ms(1);
      if (input(signal_A) == 0)
         count_low_signal_A++;
         count_high_signal_A = 0;
         count_low_signal_A = 0;
         count_high_signal_A++;
      if (input(signal_B) == 0)
         count_low_signal_B++;
         count_high_signal_B = 0;
         count_low_signal_B = 0;
         count_high_signal_B++;
   while((count_low_signal_A < COUNT_TARGET) && (count_high_signal_A < COUNT_TARGET) || (count_low_signal_B< COUNT_TARGET) && (count_high_signal_B < COUNT_TARGET));
int get_signals_state(void)
   return input(signal_A) * 2 + input (signal_B);
void clear_output_pins(void)
   int16 Pulse_time;
   if (input(Pulse_Width)==0)
      Pulse_time = pulse_time_short;
      Pulse_time = pulse_time_width;
   delay_us(Pulse_time);
   if (input(Output_invert)==0)
         output_low(encoder_UP);
         output_low(encoder_DOWN);
      #ifdef UART
         delay_us(1);
         output_high(encoder_UP);
         output_high(encoder_DOWN);
       #ifdef UART
         delay_us(1);
void set_output(int state)
   switch (state) {
      case 0:
         // rotar in the same state
      case -1:
         // step back
         #ifdef UART
            printf("minus");
      case 1:
         // forward
         #ifdef UART
            printf("plus");
      case 2:
         //error state
         OLD_states = NEW_states;
         #ifdef UART
            printf("error");
/*#INT_RTCC
void  RTCC_isr(void)
/*#INT_RA
void  RA_isr(void)
   debounce_inputs();
   NEW_states = get_signals_state();
   clear_output_pins();
   delay_ms(500);    //time to stabilize all  voltages
   int QEM [16] = {0,-1,1,2,1,0,2,-1,-1,2,0,1,2,1,-1,0};           // Quadrature Encoder Matrix
   debounce_inputs();
   OLD_states = NEW_states = get_signals_state();
   int Out;
   //enable_interrupts(INT_RA);
   //enable_interrupts(INT_RTCC);
   //enable_interrupts(GLOBAL);
   // input signals debounce
      debounce_inputs();
   // input signals debounce end
   // rotary encoder Grey code decoding
      Out = QEM [OLD_states * 4 + NEW_states];     // Out = -1 move backward, Out = +1 move forward Out= 0 same possition Out = 2 error eg. input noise
   // rotary encoder Grey code decoding END
   // output set
      set_output(Out);
      #ifdef debug_slower
         delay_ms(1500);
   // output set end
The code is without interrupts because the chip does this work only, but maybe someone will improve it and make interrupts work.
silelis
PostPosted: Fri Apr 28, 2017 5:51 am     Reply with quote
It is updated ELM402 emulator. Fixed some issues.
    @file     ELM402_emu.c
    @author   Dawid "SileliS" Bankowski (d.bankowski@gmail.com)
    @brief    ELM 402 software emulator.
    @section LICENSE
    Software License Agreement (BSD License)
    Copyright (c) 2015, D. Bankowski
    All rights reserved.
    Redistribution and use in source and binary forms, with or without
    modification, are permitted provided that the following conditions are met:
    1. Redistributions of source code must retain the above copyright
    notice, this list of conditions and the following disclaimer.
    2. Redistributions in binary form must reproduce the above copyright
    notice, this list of conditions and the following disclaimer in the
    documentation and/or other materials provided with the distribution.
    3. Neither the name of the copyright holders nor the
    names of its contributors may be used to endorse or promote products
    derived from this software without specific prior written permission.
    THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ''AS IS'' AND ANY
    EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
    WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
    DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER BE LIABLE FOR ANY
    DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
    (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
    LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
    ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
    SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
//#include <18F4520.h>
//#include <12F629.h>
#include <12F683.h>
#define device getenv("DEVICE")
#define _use_UP_DOWN_      //if defined output is Voltage level (UP/DOWN) or ifndef output is UART (UART is for debug only)
#define ELM402_debounce_period   10    //10 times
#define ELM402_debounce_delay    50    //uS 50
#define ELM_startup_time_delay   50    //mS
#define ELM402_pulse_time        200   //uS
#define ELM402_pulse_width_additional_time  1800  //uS
#if device=="PIC18F4520"
   #warning device
   #warning OSCCAL exists getenv("SFR_VALID:OSCCAL")
   #if getenv("SFR_VALID:OSCCAL")!=0
      #warning at getenv("SFR:OSCCAL")
    #warning   RCON getenv("SFR:RCON")
    #byte      RCON = getenv("SFR:RCON")
    #warning   BOR getenv("SFR:RCON").0
    #bit       BOR = RCON.0
   //#device ADC=10
   #FUSES nomclr, BROWNOUT
   #define rotoencoder_port_interrupt INT_RB
   /*ELM402 emulation definitions*/
   //input definition
   #define signal_B           PIN_B4
   #define signal_A           PIN_B5
   #define pulseWidth         PIN_B1
   #define outputInvert       PIN_B2
   //output definition
   #define output_UP           PIN_C6
   #define output_DOWN         PIN_C7
   #ifndef _use_UP_DOWN_
      #WARNING "TTL OUTPUT"
      #use rs232(baud=9600,parity=N,xmit=output_UP,rcv=output_DOWN,bits=8)
#if device=="PIC12F629"
   #warning device
    #warning   PCON getenv("SFR:PCON")
    #byte      PCON = getenv("SFR:PCON")
    #warning   BOD getenv("SFR:PCON").0
    #bit       BOD = PCON.0
   #define rotoencoder_port_interrupt INT_RA
   //input definition
   #define pulseWidth         PIN_A3
   #define outputInvert       PIN_A2
   //output definition
   #define output_UP           PIN_A0
   #define output_DOWN         PIN_A1
      #use rs232(baud=9600,parity=N,xmit=output_UP,rcv=output_DOWN,bits=8) //,stream=PORT1)
#if device=="PIC12F683"
   #warning device
   #warning OSCCAL exists getenv("SFR_VALID:OSCCAL") //at getenv("SFR:OSCCAL")
    #warning   BOR getenv("SFR:PCON").0
    #bit       BOR = PCON.0
   //#device ADC=10
   //input definition
   //output definition
int OLD_states;
int NEW_states;
const int QEM [16] = {0,-1,1,2,1,0,2,-1,-1,2,0,1,2,1,-1,0};
signed int Out;
int pulses;
void debounce_inputs(int16 time2debounce);      //ELM402 debounce emulation - waits till there is no voltage oscillation on signal_A and signal_B
int get_signals_state(void);     //returns rotor encoder state - inputs are signal_A and signal_B
/* Rotar encoder onPort change interrupt */
   #INT_RB
   #INT_RA
   #INT_RA
void  onPORT_changes_isr(void)
   //disable_interrupts(rotoencoder_port_interrupt);
   //OLD_states = NEW_states;
   debounce_inputs(ELM402_debounce_period);
   //pulses=pulses+1;
   NEW_states = input_state(signal_A) * 2 + input_state (signal_B);
   //printf("%d %d \n\r", input_state(Pin_B5), input_state(Pin_B4));
   //if (QEM [OLD_states * 4 + NEW_states]!=2)
   Out = Out+ QEM [OLD_states * 4 + NEW_states];
   //printf("\033[H\033[J");
      if (BOD==0)
         reset_cpu();
   pulses=pulses+1;
   if (pulses==4)
      if (Out>3)     //Rotor encoder increment condition
            if (input_state(outputInvert))
               printf("minus ");
               printf("plus ");
         #ifdef _use_UP_DOWN_
            output_bit( output_UP, 1-input_state(outputInvert));
      else if (Out<-3)     //Rotor encoder decrement condition
               printf("plus ");
               printf("minus ");
               output_bit( output_DOWN, 1-input_state(outputInvert));
      else //if ((Out<3)&(Out>-3)) //Rotor encoder error condition (i.e. rotor contact are corrupted)
            printf("error ");
            #asm
              // nop;
            #endasm
   Out=0;
   pulses=0;
   delay_us(ELM402_pulse_time+input_state(pulseWidth)*ELM402_pulse_width_additional_time);
   //#todo: clear outputs
    //  printf("\033[H\033[J"); // terminal clear
      output_bit( output_UP, 0+input_state(outputInvert));
      output_bit( output_DOWN, 0+input_state(outputInvert));
   enable_interrupts(rotoencoder_port_interrupt);
#zero_ram
   OLD_states = NEW_states = input_state(signal_A) * 2 + input_state (signal_B);
   pulses=0;
   Out=0;
   delay_ms(ELM_startup_time_delay);
   /*------ Brownout reset ------*/
   /* for PIC18f4520 or PIC12f683*/
   /*#if device!="PIC12F629"
      brownout_enable (TRUE);
      BOR=1;
   #endif*/
   /* for PIC12f629              */
   /*#if device=="PIC12F629"
      BOD =1;
   #endif*/
   /* for PIC12f629
      if (BOD==0)
         printf("BOR");
   #endif*/
  //delay_ms(2500);
   do
      delay_us(ELM402_debounce_delay);
   while((count_low_signal_A < time2debounce) && (count_high_signal_A < time2debounce) || (count_low_signal_B< time2debounce) && (count_high_signal_B < time2debounce));
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
