SPI Read returns only 0 in slave when I hook up SS to INT
vsmguy
PostPosted: Thu Apr 18, 2013 10:03 am     Reply with quote
I am coding a SPI slave using a PIC16F877A and need to be aware when the SS line goes from high (idle) to low (active) as information from the master is framed as a stream of bytes with the leading byte (first byte after SS goes active) telling me what the remaining bytes are for.
I have shorted SS (from master) to INT and written this:
#include <16F877A.h>
#device adc=16
#device *=16
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#use rs232(baud=57600,parity=N,xmit=PIN_C6,rcv=PIN_C7, ERRORS)
// TODO: add a 100ohm resistor between the SS pin and the chip select output of the master microcontroller                                                     // Clock base   Sample on
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H)   //    high      trailing edge
volatile int1 slave_cs_enabled = false; //has the salve STB been enabled?
//#PRIORITY EXT, SSP
#PRIORITY INT_EXT, INT_SSP
#INT_EXT
void slave_cs_isr()
   slave_cs_enabled = true;
//#INT_SSP
   unsigned int8 data = 0;
   enable_interrupts(INT_EXT);
   ext_int_edge( H_TO_L );
   clear_interrupt(INT_EXT); //if you read the data sheet, you will
   //Now the code will call the interrupt in the rising edge.
   setup_spi(SPI_SLAVE | SPI_MODE_3);
   while(1) {
      if(slave_cs_enabled)
         printf("STB\n\r");
      if(spi_data_is_in())
         data = spi_read();
         printf("%X\n\r", data);
All I get after STB are "00". When I take out the STB logic, I get stream of bytes but that is not useful to me as I now don't know where a stream starts and ends.
Help!
alan
PostPosted: Thu Apr 18, 2013 10:45 am     Reply with quote
You have to read the pin to clear the interrupt, otherwise it keeps on interrupting.
PostPosted: Thu Apr 18, 2013 3:20 pm     Reply with quote
Not for int_ext. Only for the interrupt on change.
Obvious question is how fast the data is being sent, and whether there is any delay between operating the select, and the data being sent. Given the way the code is written, there is a huge delay before you check if data has arrived, so if multiple bytes are sent, something will be lost. Time to get into and out of the interrupt, and then the time to print the message. A total of about 600uSec, before the 'data is in' flag is tested....
vsmguy
PostPosted: Thu Apr 18, 2013 3:29 pm     Reply with quote
Sure, but given that the master sends out mostly non-zero values, I find it difficult to believe this PIC slave does not see at-least one non zero value.
I will put in a #int_ssp ISR and see what I get.
In the meantime, could the issue be that I defined the priority:
but never defined a INT_SSP ISR in reality?
PostPosted: Fri Apr 19, 2013 12:42 am     Reply with quote
#priority does basically nothing....
All it does is specify the _order_ the interrupt flags will be checked in the global ISR. If you don't have a priority entry, they are checked in the order they are defined in the code.
