fat.c Problem Not Enough Ram error *** Locked - old thread
Post new topic   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> General CCS C Discussion
fahdovski
PostPosted: Sat Dec 19, 2009 1:24 pm     Reply with quote
#include "D:\INSAT_electronique\PIC C PROJECT\ddd\enfin.h"
#include <fat.h>
char filename[]="test.txt";
char mode[]="w";
FILE stream;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
   // TODO: USER CODE!!
   if(fatopen(filename,mode , &stream) != GOODEC)
      printf("Error opening file");
      return;
i got not Enough RAM for All variable
What should i do plz Crying or Very sad Crying or Very sad
AAA000
SAME PROBLEM HERE
PostPosted: Sat Dec 19, 2009 1:50 pm     Reply with quote
Anyone get any idea? I have the same problem.
PostPosted: Sat Dec 19, 2009 3:04 pm     Reply with quote
OK folks, again...what model is the PIC and what is the CCS version?
fahdovski
Same
PostPosted: Sat Dec 19, 2009 3:10 pm     Reply with quote
PIC16F877
ccs 4.084
PostPosted: Sat Dec 19, 2009 3:32 pm     Reply with quote
I seriously doubt if the 16F877, has enough RAM. You will definitely need the option:
#device *=16
in your enfin.h file, as the line immediately after including the processor defines, to have 'any hope'...
martind1983
Re: fat.c Problem Not Enough Ram error
PostPosted: Mon Apr 15, 2013 7:38 am     Reply with quote
#include <fat.h>
char mode[]="w";
FILE stream;
   setup_adc(ADC_OFF);
      return;
First off you try to read comments in FAT.c library and you will immediately see that first you have to use fat_init function before using of any other functions. Second the issue can really be in small RAM memory of your MCU. You should read datasheet and then you will know if that's not problem.
Last thing in your code on this forum don't use this if(fatopen(filename,mode , &stream) != GOODEC) in condition because you don't know if the compiler doesn't throw return value first and then it compares condition with incorrect value. You rather use this
int8 check;
if((check =fatopen(filename,mode , &stream)) != GOODEC)
martind1983,
Do not reply to old threads from 2009.
No one is waiting for the reply.
- Forum Moderator
PostPosted: Mon Apr 15, 2013 8:01 am     Reply with quote
also...
unless you use PROPER signal translation hardware you'll never get a 5 volt PIC to 3 volt memory card.Can't be done..
So before you go any further, show us the schematic of what you have..or the pinout connections.
No sense blaming software if you have wrong hardware !!
hth
jay
temtronics,
You too. Check the thread date.
- Forum Moderator
Post new topic   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> General CCS C Discussion All times are GMT - 6 Hours
