how to exceed the 255 length limit of byte table
Goto page 1, 2  Next
josephazzam
PostPosted: Fri May 03, 2013 6:25 am     Reply with quote
Hi, I'm programming a pic,
and I have a table of byte: byte a[300];
but when I reach a[255] in a for loop
The table go back to a[0]
Any ideas ?
Thank You
Gabriel
PostPosted: Fri May 03, 2013 6:36 am     Reply with quote
What is your chip number?
in Ram or on the local EEPROM?
CCS PCM 5.078 & CCS PCH 5.093
josephazzam
PostPosted: Fri May 03, 2013 6:42 am     Reply with quote
I am using pi18f4520, but I do not see how's that relevant since the problem is in the code, it compiles but what happens that:
when I store values :
for(i=0;i<300;i++)
a[i]=i/2;
the result would be:
a[0] = 0 ;
a[1] = 1/2 ;
then when it passes i=256
I get:
a[0] = 256/2 ;
a[1] = 257/2 ;
the byte table is limited to 256 bytes then is start over
ezflyr
As a newbie to the CCS forum, you should be made aware of the forum guidelines: http://www.ccsinfo.com/forum/viewtopic.php?t=47549
If you answer all four of the bullet points in the first post in that thread then we can help you.
John
josephazzam
PostPosted: Fri May 03, 2013 6:50 am     Reply with quote
version 4.114
microchip pic18f4520
josephazzam
PostPosted: Fri May 03, 2013 6:51 am     Reply with quote
void displaystring(byte *PORT, byte Alphabet[40][6])
char MyStr[90] = "PLEASE FEAL FREE TO INSERT YOUR FINGER - WE ARE NOT RESPONSIBLE FOR WHAT MIGHT HAPPENS - " ;
byte tab[540];
byte temp;
int i,j;
int16 a;
for(i=0 ; i < 89 ; i++)
if((MyStr[i]>='A') && (MyStr[i]<='Z' ))
for(j=0 ; j< 6 ; j++ )
tab[(i*6)+j] = Alphabet[ MyStr[i] -65 ][j] ;
if((MyStr[i]>='0') && (MyStr[i]<='9'))
tab[(i*6)+j] = Alphabet[ MyStr[i] -22 ][j] ;
if(MyStr[i]=='_')
tab[(i*6)+j] = Alphabet[ 37 ][j] ;
if(MyStr[i]=='.')
tab[(i*6)+j] = Alphabet[ 38 ][j] ;
if(MyStr[i]=='-')
tab[(i*6)+j] = Alphabet[ 39 ][j] ;
tab[(i*6)+j] = Alphabet[ 36 ][j] ;
josephazzam
PostPosted: Fri May 03, 2013 6:52 am     Reply with quote
well this is the original example,
if I change the max value in the for loop from 89 to 42, the software works properly
but after 42, since 43*6 >256, I get problems
ezflyr
PostPosted: Fri May 03, 2013 6:54 am     Reply with quote
Please reread step #4 in the link I sent previously, and also use the 'Code' button when posting your Small, Compilable program that shows the problem........
John
josephazzam
PostPosted: Fri May 03, 2013 6:55 am     Reply with quote
if(MyStr[i]=='_')
if(MyStr[i]=='.')
if(MyStr[i]=='-')
josephazzam
PostPosted: Fri May 03, 2013 6:57 am     Reply with quote
this is a small compilable function, just put it in a main.
if you want something more simple just see the example I've putter about (the a[i] = i/2)
ezflyr
PostPosted: Fri May 03, 2013 6:58 am     Reply with quote
Do you know what 'compilable' means? It means a piece of code that I can
simply cut and paste, and compile myself.
I'm beginning to see where the problem lies here. You aren't big on following instructions are you?
My guess is that some of your variable defines are wrong, but you aren't showing any of that! Not relevant, you say?
John
josephazzam
PostPosted: Fri May 03, 2013 6:59 am     Reply with quote
the problem is simple the after 256 it goes back to 0 :
a[0] a[1]...... a[255] a[0] a[1] instead of going to a[256] a[257]
josephazzam
PostPosted: Fri May 03, 2013 7:00 am     Reply with quote
I can't give you a small code,
I need to give you the entire code because it's not independant, and the isis file too
ezflyr
PostPosted: Fri May 03, 2013 7:02 am     Reply with quote
If the problem is 'simple' (your words!), then it should be possible to write a small program to demonstrate the problem......
If you want to rigidly dictate how we must help you, then good luck solving your problem!
John
Gabriel
PostPosted: Fri May 03, 2013 7:26 am     Reply with quote
Easy guys...
think about this:
how many bits in a byte?
what is the largest number you can hold with that many bits?
what happens if you increment the number of bits?
diferences between int and int16?
Max expected value? does that fit in an "int" or do you need an int16? or Larger?
G.
Goto page 1, 2  Next
Page 1 of 2
