string tokens and save in arrays
syeda amna
PostPosted: Thu Mar 14, 2013 6:54 am     Reply with quote
Hi
I want to develop code such that it compares the string separated by "/". What i m missing.
the ouput shows data[0]=0123456789 abd data[1]=Null. why??
#include <18F452.h>
#fuses HS,NOWDT,NOLVP,PUT,NOPROTECT,BROWNOUT
#use delay(clock=16M)
#fuses XT
#include <string.h>
int8 i=0;
int8 x;
char line[40] = {"0123456789/0123456789"};  //sample string
char sep[] = {"/"};
char *data ;
//==========Use strtok() function to to match string========//
   data[i] = strtok(line, sep);   //It separates this "/"
    for(i=1;i<2;i++)
       data[i] = strtok(0, sep);
     for(x=0;x<2;x++){
     puts(data[x]);
     if(data[0]==data[1])
       puts("correct");
PostPosted: Thu Mar 14, 2013 7:16 am     Reply with quote
The first search will return the entire string, then the subsequent ones are not searching in the string at all, but in the memory starting at address zero. Not where you are meant to be looking....
syeda amna
PostPosted: Thu Mar 14, 2013 11:41 am     Reply with quote
what will be the solution? Question
PostPosted: Thu Mar 14, 2013 12:35 pm     Reply with quote
As a side note, your code below has a serious mistake. First you
specify the HS fuse, which is correct for a 16 MHz crystal. But then
for some strange reason, you add a separate line with the XT fuse
which is for a 4 MHz crystal.
#include <18F452.h>
#fuses XT
How does the compiler handle two different oscillator fuses ?
It uses the last one. See the list of fuses compiled by the compiler
at the end of the .LST file, below. It's using the XT fuse, which will
not work with a 16 MHz crystal. So if you are running real hardware,
the PIC will not run.
Configuration Fuses:
Word 1: 2100 XT NOOSCSEN
Word 2: 0E0E PUT BROWNOUT BORV20 NOWDT WDT128
Word 3: 0100 CCP2C1
Word 4: 0081 STVREN NOLVP NODEBUG
Word 5: C00F NOPROTECT NOCPB NOCPD
Word 6: E00F NOWRT NOWRTC NOWRTB NOWRTD
Word 7: 400F NOEBTR NOEBTRB
syeda amna
PostPosted: Fri Mar 15, 2013 1:37 am     Reply with quote
thanks PCM Programmer for explaining the fuses.
I want to ask is there any builtin function that can produce the output like this.
data[0]=0123456789
data[1]=0123456789
I think the code should produce the output like this. but it didnt. the value in data[1] is NULL.
PostPosted: Fri Mar 15, 2013 2:03 am     Reply with quote
There are several problems.
First, data[i], for i>0 doesn't exist. You are creating a single pointer, not an array....
Then the command passed to strtok, for the later values, should be NULL, not 0 (it may well _be_ zero, but this is not guaranteed - use the correct value).
Then data[0], will never equal data[1] - remember these are string pointers. The first will point to the start of the first string token, the second the second token - not equal. I suspect you want to compare strings, so need to look at strcmp....
So:
   int8 i=0;
   int8 x;
   char sep[] = {"/"};
   char data[3] ;
   for(i=1;i<2;i++)
      data[i] = strtok(NULL, sep);
   for(x=0;x<2;x++)
      puts(data[x]);
   if(strcmp(data[0],data[1])==0)
       puts("correct");
   while(TRUE) ; //If you don't do this, the print will never complete as
   //the code will fall off the end and go nowhere....
syeda amna
PostPosted: Fri Mar 15, 2013 2:24 am     Reply with quote
Great!!! Ttelmah Smile
I want to compare and the print the values in data[0] and data[1].
Now how can i print these values??
bkamen
PostPosted: Fri Mar 15, 2013 2:43 am     Reply with quote
Well -- yes.. I would always make sure to read the datasheet.
As I recall (and again, I would check cause this stuff changes)
HS is for >= 8MHz
XT is for <= 8MHz
But could vary based on which PIC.
otherwise... yes yes on all other accounts. (16MHz and XT do not mix)
Dazed and confused? I don't think so. Just "plain lost" will do. :D
PostPosted: Fri Mar 15, 2013 2:51 am     Reply with quote
Er.
The code I have posted, prints them, and compares them.
