Fabrici
Joined: 11 Feb 2013 Posts: 19 Location: Toulouse - France
stack problem with mmcsd_load_buffer |
Posted: Wed Mar 06, 2013 11:15 am |
I'm using CCS PCD C Compiler, Version 4.140, 7054
I'm currently trying to communicate between a DSPIC33EP256GP506 and a micro SD card. The function "mmcsd_init()" is returning a bad code (MMCSD_ADDR_ERR), so I build a minimal code to try to isolate the problem. Here is my test code :
Code: | #include <33EP256GP506.h>
#FUSES ICSP1 // ICD uses PGC1/PGD1 pins
#FUSES NOJTAG // JTAG disabled
#FUSES DEBUG // Debug mode for use with ICD
#fuses NOALTI2C1 // I2C1 mapped to ASDA1/ASCL1 pins
#fuses NOALTI2C2 // I2C2 mapped to ASDA2/ASCL2 pins
#FUSES NOWDT // No watchdog timer
#FUSES FRC_PLL //Internal Fast RC oscillator with PLL
#BUILD (STACK=0x1000:0x1200)
#USE delay (clock=50000000)
// Déclarations pour carte SD
#use fast_io(a)
#use fast_io(c)
#define MMCSD_PIN_SCL PIN_C3 // o
#define MMCSD_PIN_SDI PIN_A9 // i
#define MMCSD_PIN_SDO PIN_A4 // o
#define MMCSD_PIN_SELECT PIN_C12 // o
#include <mmcsd.c>
// Programme principal //
int iRes;
//// Lecture des valeurs dans la carte SD
iRes = mmcsd_init();
//// Boucle principale ////
do
} while (TRUE);
When I debug the code, everything seems to go well until the last instruction of the mmcsd_init() : r1 = mmcsd_load_buffer(); .
code of the mmcsd_load_buffer() :
Code: | MMCSD_err mmcsd_load_buffer(void)
g_MMCSDBufferChanged = FALSE;
return(mmcsd_read_block(g_mmcsdBufferAddress, MMCSD_MAX_BLOCK_SIZE, g_mmcsd_buffer));
Here, g_mmcsdBufferAddress is set to 0x00000000 . But when I continue to debug :
Code: | MMCSD_err mmcsd_read_block(uint32_t address, uint16_t size, uint8_t* ptr)
MMCSD_err ec;
uint16_t i; // counter for loops
address has been changed to 0x20082008 .... and code will exit with MMCSD_ADDR_ERR.
I'm not fluent with assembler language, but I hope it will help : here are some parts of the .lst file :
Code: | .................... return(mmcsd_read_block(g_mmcsdBufferAddress, MMCSD_MAX_BLOCK_SIZE, g_mmcsd_buffer));
0053A: PUSH 1402
0053C: POP 140A
0053E: PUSH 1404
00540: POP 140C
00542: MOV #200,W4
00544: MOV W4,140E
00546: MOV #1202,W4
00548: MOV W4,1410
0054A: CALL 46C |
I'm a bit surprised with the adresses of the push and pop, which seems to not be in the stack, but as I said before I'm not very fluent in assembler language.
Has anybody encountered this kind of problem ?
Best regards
Fabrice |
Fabrici
Posted: Thu Mar 07, 2013 11:56 am |
Looking at the .sym file, I was surprised to see same address allocated to different symbols involved in my problem :
1408 mmcsd_init.i
1409 mmcsd_init.r1
140A mmcsd_crc_on_off.crc_enabled
140A-140D mmcsd_set_blocklen.blocklen
140A-140D mmcsd_read_block.address
140E-140F mmcsd_read_block.size
1410-1411 mmcsd_read_block.ptr
1412 mmcsd_read_block.ec
But maybe this is a misunderstanding on my part. Could someone explain to me this assignment ?
Best regards,
Fabrice |
Posted: Thu Mar 07, 2013 12:54 pm |
That is quite normal.
Variables form a 'tree'. The bottom layer is the global variables. Then static variables. Then local variables in main, then local variables in each function, and so on as functions call functions.
A function at the top of the tree uses a variable in a memory location. When it exits, this memory is no longer in use, and another function at the same level can re-use the same memory. This is why it is vital to never 'assume' that a variable will hold it's value (and to declare as static if you want it to do so).
Memory is re-used, and several variables in different routines can use the same area. The key is (of course), that functions that call other functions, cannot have an area re-used by routines that it calls.
Your problem has come up not that long ago. If I remember, I tried the code, duplicated the problem, and fixed it, and posted this. I can't remember what it was and on a different machine, so can't look up my notes. A search should find the thread. Was it the one where the functions required ANSI mode?. I think it might be.
