#priority on 16F does not work
subkron
PostPosted: Tue Mar 05, 2013 10:02 am     Reply with quote
Pretty straightforward, I have a design using a 16F1829 and I want to set the CCP2 interrupt as the first to be checked in the handler. No matter what I do (changing the order of the int_xx functions or assigning the order using #priority) the hander always goes in the order of T0, T1, CCP2 and RA when I check the list file. Compiler version V4.135.
Does this directive (#priority) actually work?
#priority int_CCP2, int_TIMER0, int_RA, int_TIMER1
#int_CCP2
void CCP2_isr(void)
   process_c();
#int_TIMER0
void  TIMER0_isr(void)
   process_a();
#int_RA
void  RA_ioc_A_B(void)
  process_d()
#int_TIMER1
void  TIMER1_isr(void)
   process_b();
PostPosted: Tue Mar 05, 2013 10:51 am     Reply with quote
It does work.
You can easily tell by looking at the assembler listing, where you will see the order the flags are tested.
Unless the interrupts are triggering at almost exactly the same time, the first triggered _will_ be the first serviced. I'd suggest that T0 is triggering first.
Mike Walne
PostPosted: Tue Mar 05, 2013 11:01 am     Reply with quote
How do you KNOW?
Mike
subkron
PostPosted: Tue Mar 05, 2013 11:04 am     Reply with quote
That's exactly what I did (looked at the assembler listing). If I re-arrange the interrupt routines the compiled address changes. However, the hander (starting at address 0x004) readjusts such that the order of the pollng for the 4 interrupts is always t0, t1, ccp2, ra. If I rearrange the order defined in #priority the handler does not change.
PostPosted: Tue Mar 05, 2013 3:15 pm     Reply with quote
Perhaps you were looking at the wrong part of the assembly listing?
I don't have v4.135 installed but tried v4.137 and there it works, when I change the priority order the interrupt flags are tested in the sequence as mentioned in the #priority statement.
000F:  CLRF   FSR0H
0010:  MOVLW  92
0011:  MOVWF  FSR0L
0012:  BTFSS  INDF0.BOR
0013:  GOTO   016
0014:  BTFSC  PIR2.CCP2IF         // CCP2
0015:  GOTO   032
0016:  BTFSS  INTCON.T0IE
0017:  GOTO   01A
0018:  BTFSC  INTCON.T0IF         // Timer0
0019:  GOTO   02E
001A:  BTFSS  INTCON.IOCIE
001B:  GOTO   01E
001C:  BTFSC  INTCON.IOCIF         // INT_RA
001D:  GOTO   034
001E:  CLRF   FSR0H
001F:  MOVLW  91
0020:  MOVWF  FSR0L
0021:  BTFSS  INDF0.BOR
0022:  GOTO   025
0023:  BTFSC  PIR1.TMR1IF         // Timer1
0024:  GOTO   030
0025:  MOVF   20,W
0026:  MOVWF  @77
0027:  MOVF   21,W
0028:  MOVWF  @78
0029:  MOVF   22,W
002A:  MOVWF  @79
002B:  MOVF   23,W
002C:  MOVWF  @7A
002D:  RETFIE
002E:  MOVLP  00            <<--  Perhaps this is the part you were looking at?
002F:  GOTO   03A            // The sequence here stays the same
0030:  MOVLP  00             // Don't understand why this in-between jump table is here.
0031:  GOTO   042
0032:  MOVLP  00
0033:  GOTO   036
0034:  MOVLP  00
0035:  GOTO   03E
Note the last part of this listing, there is an intermediate jump table of which the sequence does stay the same when the #priority line is changed.
I don't understand why this extra jump table is there. It doesn't seem to add extra functionality.
PostPosted: Tue Mar 05, 2013 3:43 pm     Reply with quote
That secondary table is a fix for one of the PIC erratas. Only exists on some chips.
subkron
PostPosted: Wed Mar 06, 2013 10:38 am     Reply with quote
From CCS support:
"The problem you reported has been fixed and will be in the next compiler release. "
Oh well...
